Full Version: Problems after Resume from Standby
Ok, background first:
I'm running the new XBMCbunutu Eden Beta3 on an Asus EeeBox 1501P.
XBMC is set up to enter Standby upon PowerOff, which happens either after 30mins of inactivity, or upon me telling it to shut down from the standard IR remote or the Android remote app. This works perfectly.
Resume from Standby also works 9 times out of 10, either from remote, app, or WakeOnLan.
Problem is, after resuming from standby, XBMC looks like it's working fine, but video files quit to the main menu after a few seconds.
A full reboot fixes the issue, but kind of makes the whole idea of standby and resume pointless.
Any ideas, where I should start looking for the cause of this weird behaviour?
The xbmc debug log perhaps? Check out system logs too, they are in /var/log/
