No problems. Feel free to mention anything you may feel is related to this patch.
Had same Nyxboard issue with a custom build. Issue was gone after a newer compile with yesterdays git version.
Confirmed. Installed the latest nightly build (Windows) and it no longer occurs.
The problem we had before and solved december 4 is still not completely fixed I am afraid. I have had occurences lately, symptom is that display of progress-dialog freezes until server is connected. Typically occurs when waking Xbmc from supend mode.
bilbonvidia
I received my pi today and tried your patch for automatic wol on mysql sources.
Are you sure you linked the correct file?
Because wol does not work for me here :-(
Do you have the wol option in power settings?
And have you enabled it and copied your wakeonlan.xml?
(2013-01-19, 12:17)t4_ravenbird Wrote: [ -> ]The problem we had before and solved december 4 is still not completely fixed I am afraid. I have had occurences lately, symptom is that display of progress-dialog freezes until server is connected. Typically occurs when waking Xbmc from supend mode.
I've not experienced this, but I'll keep an eye out for it.
(2013-01-19, 06:27)gibxxi Wrote: [ -> ]Confirmed. Installed the latest nightly build (Windows) and it no longer occurs.
I'll make a new build soon to fix this issue and have the WOL features.
bilbonvidia
my bad - I found it out on myself last night... just forgot to enable that option.
works like a charm!
Thank you!
Thanks Kricker, will check it out.
(2013-01-23, 04:02)kricker Wrote: [ -> ]New Windows build available now.
XBMCSetup-20130120-55e1e26-WOA
This has solved my problems. Thank you. Why isn't this a part of the official xbmc I wonder.
Needs to be reviewed and tweaked to make sure it breaks nothing else. The next release is right around the corner. Hopefully this PR will make it into mainline soon once devs had a minute to breath after getting Frodo ready.
bilbonvidia
I'm currently running your build without any problems, so thank you again for your help!
