2012-03-02, 23:25
Hi guys.
So I finally bit the bullet and decided to try Eden. Now as I have 3 other members of the family who get upset when I change things I wanted to leave my existing installation of Dharma alone. So I thought I would install Eden on a SD card to run on my Acer Revo. That way I can tinker and play with everything and when its all sweet just change the boot order.
I downloaded the XBMCbuntu Beta 3 iso and have created a usb stick with Lili. No problems so far. The disk boots, I get the try or install screen and I can run XBMC from the try screen.
When I first chose install I got the You need 3.7g Connected to the internet etc and they both had green lights.
Then it bought up the list of options, (from memory said things like install over dharma, next to dharma or something else) so I chose something else.
Then I was able to choose the sd card as the target and boot grub target.
It then said that I had no root file system and had to change that in partition manager. So I set two partitions (ext4 and swap) then clicked install.
I then chose my area then language and keyboard and then I get an error that the partition can not be created.
I tried again. and again.
So I then used fdisk to make the partitions and mkfs.ext to set the filesystem and tried again with the same result.
I have also tried the delete and install option and still get the error writing the ext 4 partition.
I don't want to try and create a new partition and install it to the HDD, mostly out of fear of wiping my install and data.
If anyone has any suggestions on what to do differently to get it to install on a SD card I would be most appreciative.
So what am I doing wrong? I have tried 2 different sd cards to no avail.
If anyone has any suggestions I am all ears.
