2012-03-03, 02:49
I'm using RC1 on a previous OpenElec-Nightly.
The error is reproducable:
1. Go to Systems
2. Arrow down
3. File Systems
4. Add new source
5. Browse
6. Windows Share [ENTER]
When clicking Enter in step 6 XBMC turns black and comes back into the main menu a few seconds later..
I removed the logfile, then clicked ENTER in Step 6 and after the menu got back I copied the logfile, so it should be quite clean.
http://pastebin.com/vq7F0xRB
Anyone else with such problems?
If it helps: I have a Zotac ZBOX HD-ND22 which is connected via LAN.
Edit:\
Just updated to the newest OpenElec-Build from 2nd march with RC2 and the problem still remains: http://pastebin.com/Mp04W5DB
1. Go to Systems
2. Arrow down
3. File Systems
4. Add new source
5. Browse
Edit:\
