2012-03-04, 05:32
I had a few issues with restoring from backups (different thread) so figured start over... blow away the database, remove XBMC and install XBMC 11.
The movies are scraping fine, but... not sure if an XBMC thing, plugin setting, or what but, the scraping is "too" picky.
I have my files setup like,
6th Day, The (2000).avi
Scraper misses them because "the" is after 6th Day... if I manually scrape it, even if I have it set at 6th Day, it still skips it because looking for "the" at the start.
I have that issue as well with series, like Blade 1, Blade 2, Blade 3.... I have a "1" in the name and even though the rest is fine, it tends to skip scraping the first one.
Is there a way around this? a setting? especially for the "the" issue... I don't recall the scraping being that picky about the name, I'm sure having "6th" was enough to find the right title or show some similar matches.
I have many files to go through... hoping someone can help. Thanks.
also... using TMDb
also... using TMDb
