(2012-05-10, 20:48)DDDamian Wrote: [ -> ]For those that absolutely can't wait, here is the final at merge with WASAPI shared removed: XBMC-AE Final
Sorry this may be a silly question, but what is the difference between this build and the nightly builds from 10/05/2012 that now feature AE?
There was a pull-request to eliminate WASAPI shared mode that didn't get merged into master along with the rest of AE. If you are using WASAPI and not DirectSound you may have issue with the first nightly (last night) that featured AE.
This build addresses that. You can use it, or wait until tomorrow when the fix will be in the new nightly.
Thanks for the clarification on this DDDamian!
Will give it a shot, keen to try out the fix for Onkyo receivers
DDDamian - this build crashes in the same way as today's nightly build did.
Quote:21:33:33 T:2780 ERROR: SQL: SQL error or missing database
Query: SELECT idVersion FROM version
21:33:33 T:2780 ERROR: CJobWorker:rocess error processing job
21:33:33 T:4508 NOTICE: StorageServer Module loaded RUN
21:33:33 T:4508 NOTICE: StorageClient-0.9.2 Starting server
21:33:33 T:4508 NOTICE: StorageServer-0.9.2 Storage Server starting C:\Users\steelman1991\AppData\Roaming\XBMC\userdata\Database\commoncache.db
21:33:33 T:444 NOTICE: -->Python Interpreter Initialized<--
21:33:33 T:2704 NOTICE: -->Python Interpreter Initialized<--
21:33:33 T:444 ERROR: SQL: SQL error or missing database
21:33:34 T:4864 ERROR: CRemoteControl::Connect - failed to connect
(2012-05-10, 22:35)steelman1991 Wrote: [ -> ]@DDDamian - this build crashes in the same way as today's nightly build did.
Steelman buddy,
Can you see if you have the random items add-on installed (it will be there if you have downlaoded Welo, which you mentioned you were downloading in a pm to me). If so, try moving it from the add-ons folder and launch xbmc.
DDDamian... the last build you posted before the merge crashed for me when the random items add-on was installed (gets downloaded and installed when Welo is downloaded).
Cheers
Liquid - had a look and can't see anything named like that - I did install Welo earlier today, but that was after I got the crashes with the nightly and reverting back to yesterday's nightly.
Cheers buddy.
(2012-05-10, 23:06)steelman1991 Wrote: [ -> ]Liquid - had a look and can't see anything named like that - I did install Welo earlier today, but that was after I got the crashes with the nightly and reverting back to yesterday's nightly.
Cheers buddy.
Ah, guess you did a fresh install then?
Cheers
I have - several of them. I did notice a script.randomitems folder - is that the one you mean?
heh - yep, that's definitely not an AE issue sorry. Random addons sounds kinda like an invite to crash too - wonder if it grabs ones marked "broken" in repo for example.
Still cant play DTS FLAC's?
(2012-05-11, 04:01)Dixon Butz Wrote: [ -> ]Still cant play DTS FLAC's?
Not yet, soon. We've asked team member DanielaE if she would help with that. If she does great, if not we'll add. Either way it's on the list.
DDDamian, I notice that when using the "Transcodeto" advanced option (set to AC3), one has to also have the pass-through for that enabled. I would think this should work regardless.
Cheers buddy.
There's some very funny thing with these latest builds. If I do a clean install of @DDDamian's AE Final, XBMC crashes after the splash screen as well. When I install it on top of the April 25 build, it works fine, except that the backgrounds are missing.
It all points to the SQL databases, which are created after the first run ... after a clean install.
I installed the nightly of May 10th and I have problems when playing FLACs with PAPlayer. The music plays fine but XBMC becomes very sluggish, almost unresponsive.
The file is 88.2kHz but plays as 48kHz.
1.76fps is a good number, most of the time it's around 0.50fps.
In the
log I found the following lines:
10:53:29 T:1956 DEBUG: Error: Requested setting (audiooutput.useexclusivemode) was not found. It must be case-sensitive
10:53:29 T:1956 DEBUG: CAESinkWASAPI::IsCompatible: Formats Incompatible due to different :Sample Rates
Is this a bug or I'm missing some kind of arcane advancedsettings knowledge?
With DVDplayer I have no speed problems.
