Full Version: Where are files I removed from 'Movies' but did not delete?
Hi Folks
First post, my brother set XBMC up for me and I removed file from Movie folder but did not delete it, how do I get it back, and how do I delete if I do not want it back.
Please be gentle with me as I am not great with Hardware/Software Rolleyes
Should be under Videos -> Files
If you want to delete it you just delete the file from your hard drive. You can also do it from the XBMC interface by enabling file deletion in the XBMC settings (System/Settings -> Appearance -> File lists)
Then when you find a file, in File view or Library view, press "c" or bring up the contextual menu and you will see a delete option as well as a "remove from library" option.
Brilliant thanks!
Do I 'Queue Item' to get it back into my Moveis?
If you attempt to get "movie info" or press "i" on the keyboard (same thing as movie info from the contextual menu) it should force XBMC to rescan that file back into the library.
Ned
Thanks for your help, I know it's probably basic stuff but not to a novice like me!
Cheers
Bill
