2012-03-04, 16:39
Hi All,
My setup is an ATV2 and a Mac using a QNAP NAS for files and MySQL Library syncing. Everything used to work very well .
I've installed RC2 on my ATV2 through NitoTV and it works fine, but then I updated my Mac by downloading the app and overwriting the one in my apps folder, the library isn't showing up at all.
I checked the SQL server and Beta2 of Eden created Music18 and Video60 DBs, in AdvancedSettings.xml these are just Music and Video so I assumed the numbers after were just a DB versions.
But now there appears in MySQL, the empty DBs Music and Video and also I have no sources in the app. Looks as though XBMC has read the advancedsettings file and set up two new DBs and is not reading the sources.xml file properly.
Does anyone know why this is happening? Settings files in '/Users/<your_user_name>/Library/Application Support/XBMC/userdata/' are correct and I've attached debugs at startup for both my Mac and ATV2.
MACOS: http://www.mediafire.com/?agqq7qr7lp9l5u2
ATV2: http://www.mediafire.com/?0bpnzl213zt475c
Thanks,
Sean
Thanks,
Sean
