thx spiff, the option works perfect!
thx spiff again .
but when i use files explorer in xbmc , if copy a unicode files name file to xbox , fatx lilmit also!
(spiff @ may 26 2005,14:11 Wrote:maybe not too obvious, i didn't find any better place to put it.
it is in settings->network->servers
it's just not there for me. i'm using a brand new daily cvs build, 5-30-2005, i compiled it myself from fresh source. i deleted the xbmc gamesave and the 0face008 folders in tdata/udata while i was at at. cleared out all of the caches in z,y,x too. this is pretty much all i can do to start fresh, no?
i still don't see the filename settings under settings-network-servers. i'm using the pm3 skin provided in the cvs by default, should i be using something else to see the settings?
edit: nevermind. i had to delete my entire cvs srouce tree and download a brand new one and now it works
- 13-06-2005 changed: fat-x limit setting also affects filemanager.
sorry it took so long, i simply forgot about it..
