I using another PC that I've used for XBMC before. I started with the HD Audio version and got the error so I uninstalled that and installed regular RC2, same error. Why would this be happening when I've installed XBMC on multiple computer with 0 issues?
you've probably run out of install licenses.
Could you describe the error?
install licenses?
The error is: I click to run XBMC and it immediately says "XBMC Has stopped working..."
Sometimes I get this error too.
If I try to launch it with remote desktop (XBMC is on my server) RC2 always fail to launch.
Beta3 did work without problem using RDT.
Error only says, Application launch faillure.
Its working now. I guess i had to insrall all Windows updates.
