yes this Folder is missing:
config\
and so the addon can't create the config.json file.
Sorry,but where can I get this line?Reinstallation does not fix this..Please Help!
Checked, this folder is present (AppData\R​oaming\Kodi\addons\plugin.video.nba\config\config.json).What to do?
Any potential update on the game's cutting out 1 minute past he hour max? Or still no luck
Getting a Script Error when playing a Live game from 'My Favorite Team' section. All past games work great, and the live game works great from the Live section.
Error:
AttributeError: 'NoneType' object has no attribute 'getElementsByTagName'
Log File:
http://pastebin.com/raw/V8QA8mNK
I'm having all sorts of issues all of a sudden. I can't even get the addon to open consistently without an error. If I do get into it, I likely get an "existing connections were forcably closed" error, and if I can get past that I can't open any streams without an error either.
I've uninstalled and reinstalled the addon, and have even uninstalled and reinstalled kodi and still having issues.
Can't confirm this. My add-on and also all streams do work normally. Maybe a local problem?
Not sure. Must be. My other video addons work fine. I've tried over a wireless connections as well as wired connection and still problems either way. I will try and take a look some more tonight, I had to give up last night.
Never mind, i seem to have figured it out. Was a local issue, my apologies.
Hello! Does anybody know how to hide the video length when watching an archived game? Kinda spoils overtimes
(2016-12-03, 07:54)the_3mp3ror Wrote: [ -> ]Hello! Does anybody know how to hide the video length when watching an archived game? Kinda spoils overtimes
Very good question. Don't think it's possible via an addon as it's an XBMC limitation. You'll want to mess with the skin itself. Ref. this thread
http://forum.kodi.tv/showthread.php?tid=291000
Until I find the time to try the above solution, me workaround is to not look at the screen while skipping the video.
On a side note, any luck with the 60fps streams? I take it we'll have to forget 60fps broadcasts for this year?
Maybe once the NFL season ends they will start 60fps
The Problem is the input, not the output.
output is 60fps, but input is 30fps.
Sent a mail to neullion to explain the problem.
