Full Version: NBA International League Pass - Add-on
(2012-04-30, 19:06)robla Wrote: [ -> ]
(2012-04-30, 14:45)Blasterke Wrote: [ -> ]
(2012-04-30, 14:37)robla Wrote: [ -> ]you need:
xbmc Eden (11.0)
BlueCop's repo installed
some repo which provides httplib2 (or manually download/install it.. link can be found in this thread)
I got :
XBMC Eden 11.0 --> Installed
BlueCop's repo --> Installed
httplib2 --> i've put this in Library/Applications --> install with zip but it doesn't do anything...
httplib2 has to be extracted to your normal addon path ..
this is done automatically by using the menu "addons/install from zip"
the locations should be
Linux: USERHOME/.xbmc/addons/script.module.httplib2
Windows7 c:/user/USER/AppData/Roaming/xbmc/addons/script.module.httplib2
Thanks I see 0.0.8 on mine now. I had httplib2 configured previously as well. Still not working here. I assume a proper login and pass is required in the addon settings for it to work?
(2012-04-30, 20:35)apanihi Wrote: [ -> ]
(2012-04-30, 14:45)Blasterke Wrote: [ -> ]I got :
sure :-)
only the short (3min) highlights/recaps are available for free.
xbmc Eden (11.0)
I got :
But this is for my ATV2 ...
(2012-05-01, 00:14)Blasterke Wrote: [ -> ]
too bad.. can't help your there..
xbmc Eden (11.0)
I got :
I have a similar issue on MAC OS.
I have:
httplib2 --> install with zip.
I am able to install NBA LP from zip file but it's a 0.0.4 ver and have no clue how to install from BlueCop's repo - it says addon damaged
Can someone provide ver 0.0.8 in zip file or a repo with httplib2? I was trying to replace files in addon dir but it doesn't work.
Quote:I have a similar issue on MAC OS.
I have:
I added a zip archive for version 0.0.8 to BlueCop's repo download page
http://code.google.com/p/bluecop-xbmc-re...ip&can=2&q=
re upped the zip
(2012-05-01, 20:09)robla Wrote: [ -> ]
I have:
[email]http://code.google.com/p/bluecop-xbmc-repo/downloads/detail?name=plugin.video.nba.zip&can=2&q=[/email]
When I try to install it I have a following error:
"Addon does not have the correct structure"
I have managed to create my own .zip file as I can not install it from repo. If any one interested pls let me now on priv
Quote:I added a zip archive for version 0.0.8 to BlueCop's repo download page
re upped the zip
I've checked and now the one available in download section works fine, thanks
I can now confirm that 0.0.7 works flawlessly on XBMC Dharma (Openelec). Smile
The plugin no longer works.
(2012-05-13, 09:17)doctor78 Wrote: [ -> ]The plugin no longer works.
Works fine over here...
great info! you couldn't give any more information...
I love complete problem summerizations :-)
it works for me ..
Strange ... I no longer can play arhived games. It worked fine a week ago.
(2012-05-13, 11:21)robla Wrote: [ -> ]
it works for me ..
Well EXCUSE me ... What kind of info can I post here so it will be usefull? Where can I get any log file info?
(2012-05-13, 14:35)doctor78 Wrote: [ -> ]Strange ... I no longer can play arhived games. It worked fine a week ago.
like the info from the xbmc.log
you will find X posts in this forum about the xbmc.log and usage of pastebin
or use the wiki
http://wiki.xbmc.org/index.php?title=Debug-log
it would also help to describe where the error occurs and the circumstances..
like:
does the addon display the game listings?
does the playback start the buffering?
is your NBA TV international subscription still valid (check via browser)?
do you use the latest version of the addon (0.0.8)?
what xbmc are you using and on which os?
Does this addon show live games if I have a registered username/password with nba.tv
(2012-05-14, 12:59)activate Wrote: [ -> ]Does this addon show live games if I have a registered username/password with nba.tv
sadly only archived games (a few hours after the games conclude) are available..
the live games use HDS (which uses fragmented mp4), which can't be played by xbmc or any known free library like ffmpeg..
