is there a solution on github?
Yeah, installed SPMC on my Fire TV and it works!!!!Wooohaaaaa, great! Tanks mark198.
on github is a solution for this problem-
anyone can paste full zip file with that changed games.py file? i do something wrong
(2017-04-22, 10:55)VladimirRS Wrote: [ -> ]Thanks for a great addon
+1
This addon is the only way ive been able to watch games on my Surface Pro. The frame rate via the nba website makes it unwatchable.
I also use it on my sony tv. The nba app on google tv always gives me lip synch problems. This addon resolves does not have those issues.
In fact there are many reasons why this îs better than the junk the nba gives us.
Thanks again
Hi WHamilton,
where exactly can I find/download the solution? Do you maybe have a link?
There is just a solution for the archive Games NOT for live Games!!!
You have to edit Line 81 in games.py in the kodi addon folder.
(2017-04-22, 20:08)VladimirRS Wrote: [ -> ]@JJPeters,
What is your problem exactly ?
Didn't find the solution description on github. Found it now and will try later.
Github fixes are working (archive games playing again)so waiting to check live games later(6pm UK time)
can anyone give direct intructions what we have to do make it work again? thanks in advance
You guys need to know that there is some major security issues with Kodi / this app. I've had someone constantly logging in to my account and changing my password / email address ever since I started using Kodi.
I've done absolutely everything required to clear it as any other issue, changed my League Pass username, changed password, changed email address, reformatted. The only thing I used those details to log in to apart from the official NBA LP website is Kodi, therefore I can only conclude that it's compromised.
I have never been hacked in any other website and am extremely careful, for anyone wondering.
I suggest EVERYONE go on to their League Pass account and check "Connected Devices", I just went and had a look and my account was connected to 5 separate devices that I've never used.
Error during installation on kodi 16.1..Please fix!
