Full Version: NBA International League Pass - Add-on
ERROR: RTMP_ReadPacket, failed to read RTMP packet header
ERROR: CDVDPlayer::OpenInputStream - error opening [rtmp://cp118328.edgefcs.net:1935/ondemand app=ondemand?e=1337067795&h=b7924bb754936e13082bc96f368fe81a playpath=mp4:u/nbamobile/vod/nba/2012/05/13/41100201/pc/3_41100201_ind_mia_2011_h_whole_1_hd?e=1337067795&h=b7924bb754936e13082bc96f368fe81a swfUrl=http://neulionms.vo.llnwd.net/o37/nba/player/nbatv/console.swf swfVfy=1]
this is the only error line in my log file
(2012-05-14, 17:11)doctor78 Wrote: [ -> ]ERROR: RTMP_ReadPacket, failed to read RTMP packet header
I just used your log data with rtmpdump and where able to view the game..
The problem is your librtmp... nothing the plugin can do there..
Do you use the xbmc 11.0 Eden release?
What operating system?
(2012-05-14, 15:22)robla Wrote: [ -> ]
(2012-05-14, 12:59)activate Wrote: [ -> ]Does this addon show live games if I have a registered username/password with nba.tv
sadly only archived games (a few hours after the games conclude) are available..
the live games use HDS (which uses fragmented mp4), which can't be played by xbmc or any known free library like ffmpeg..
I see. Thanks. What a pity though.
(2012-05-14, 21:09)robla Wrote: [ -> ]
The point is that the plugin worked fine till couple of day ago! I didn't do any updates or changes to my setup which is ATV2 with xbmc 11 eden.
(2012-05-15, 20:10)doctor78 Wrote: [ -> ]
I can only tell you that the plugin created a valid rtmp link/command string..
your not working playbacks are caused by the rtmp library ("RTMP_ReadPacket, failed to read RTMP packet header")..
maybe the initial rtmp answer is too slow for the default timeout.. did you try to play the link a second time (after the initial automatically started playback attempt)?
sorry, but there's nothing more I can do to help you (got no atv2) ..
17:51:03 T:110682112 NOTICE: -----------------------------------------------------------------------
17:51:03 T:110682112 NOTICE: Starting XBMC (11.0 Git:20120321-14feb09), Platform: Darwin iOS (11.0.0 AppleTV2,1, Version 5.0.1 (Build 9A406a)). Built on Mar 21 2012
17:51:03 T:110682112 NOTICE: special://xbmc/ is mapped to: /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome
17:51:03 T:110682112 NOTICE: special://xbmcbin/ is mapped to: /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome
17:51:03 T:110682112 NOTICE: special://masterprofile/ is mapped to: /var/mobile/Library/Preferences/XBMC/userdata
17:51:03 T:110682112 NOTICE: special://home/ is mapped to: /var/mobile/Library/Preferences/XBMC
17:51:03 T:110682112 NOTICE: special://temp/ is mapped to: /var/mobile/Library/Preferences/XBMC/temp
17:51:03 T:110682112 NOTICE: special://frameworks/ is mapped to: /var/stash/Applications/XBMC.frappliance/Frameworks
17:51:03 T:110682112 NOTICE: The executable running is: /var/stash/Applications/XBMC.frappliance/XBMC
17:51:03 T:110682112 NOTICE: Local hostname: Apple-TV
17:51:03 T:110682112 NOTICE: Log File is located: /var/mobile/Library/Preferences/xbmc.log
17:51:03 T:110682112 NOTICE: load settings...
17:51:03 T:110682112 NOTICE: special://profile/ is mapped to: special://masterprofile/
17:51:03 T:110682112 NOTICE: loading special://masterprofile/guisettings.xml
17:51:03 T:110682112 NOTICE: Getting hardware information now...
17:51:03 T:110682112 INFO: Using digital output
17:51:03 T:110682112 INFO: AC3 pass through is disabled
17:51:03 T:110682112 INFO: DTS pass through is disabled
17:51:03 T:110682112 INFO: AAC pass through is disabled
17:51:03 T:110682112 INFO: MP1 pass through is disabled
17:51:03 T:110682112 INFO: MP2 pass through is disabled
17:51:03 T:110682112 INFO: MP3 pass through is disabled
17:51:03 T:110682112 DEBUG: Error: Requested setting (videoscreen.screenmode) was not found. It must be case-sensitive
17:51:03 T:110682112 NOTICE: Checking resolution 12
17:51:03 T:110682112 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:51:03 T:110682112 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
17:51:03 T:110682112 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
17:51:03 T:110682112 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
17:51:03 T:110682112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
17:51:03 T:110682112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
17:51:03 T:110682112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/rtmp/mms/udp
17:51:03 T:110682112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
17:51:03 T:110682112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
17:51:03 T:110682112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
17:51:03 T:110682112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: flv/aacp/sdp
17:51:03 T:110682112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
17:51:03 T:110682112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
17:51:03 T:110682112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdfile
17:51:03 T:110682112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
17:51:03 T:110682112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
17:51:03 T:110682112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
17:51:03 T:110682112 NOTICE: Loaded playercorefactory configuration
17:51:03 T:110682112 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:51:03 T:110682112 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:51:03 T:110682112 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
17:51:03 T:110682112 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
17:51:03 T:110682112 NOTICE: Default DVD Player: dvdplayer
17:51:03 T:110682112 NOTICE: Default Video Player: dvdplayer
17:51:03 T:110682112 NOTICE: Default Audio Player: paplayer
17:51:03 T:110682112 NOTICE: Disabled debug logging due to GUI setting. Level 0.
17:51:03 T:110682112 NOTICE: Log level changed to 0
17:51:03 T:110682112 NOTICE: Loading media sources from special://masterprofile/sources.xml
17:51:03 T:110682112 NOTICE: GL_VENDOR = Imagination Technologies
17:51:03 T:110682112 NOTICE: GL_RENDERER = PowerVR SGX 535
17:51:03 T:110682112 NOTICE: GL_VERSION = OpenGL ES 2.0 IMGSGX535-63.14.2
17:51:03 T:110682112 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.0
17:51:03 T:110682112 NOTICE: GL_EXTENSIONS = GL_OES_depth_texture GL_OES_depth24 GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_float GL_OES_texture_half_float GL_OES_vertex_array_object GL_EXT_blend_minmax GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_discard_framebuffer GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_texture_lod GL_EXT_texture_filter_anisotropic GL_APPLE_framebuffer_multisample GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_APPLE_texture_max_level GL_IMG_read_format GL_IMG_texture_compression_pvrtc
17:51:04 T:110682112 NOTICE: initializing playlistplayer
17:51:04 T:110682112 NOTICE: DONE initializing playlistplayer
17:51:05 T:111476736 NOTICE: -->Python Interpreter Initialized<--
17:51:05 T:110682112 NOTICE: initialize done
17:51:05 T:110682112 NOTICE: Running the application...
17:51:05 T:111476736 NOTICE: downloader ARGV: ['']
17:51:06 T:112271360 NOTICE: -->Python Interpreter Initialized<--
17:51:06 T:110682112 NOTICE: ES: Starting event server
17:51:06 T:123559936 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
17:51:06 T:123559936 NOTICE: UDP: Listening on port 9777
17:51:06 T:110682112 NOTICE: starting zeroconf publishing
17:51:08 T:122953728 NOTICE: -->Python Interpreter Initialized<--
17:51:08 T:112271360 NOTICE: StorageServer Module loaded RUN
17:51:08 T:112271360 NOTICE: StorageClient-0.9.2 Starting server
17:51:08 T:112271360 NOTICE: StorageServer-0.9.2 Storage Server starting /var/mobile/Library/Preferences/XBMC/userdata/Database/commoncache.db
17:51:14 T:94523392 NOTICE: -->Python Interpreter Initialized<--
17:51:16 T:128237568 NOTICE: -->Python Interpreter Initialized<--
17:51:19 T:122953728 NOTICE: -->Python Interpreter Initialized<--
17:51:21 T:122953728 NOTICE: -->Python Interpreter Initialized<--
17:51:23 T:110682112 NOTICE: DVDPlayer: Opening: rtmp://cp118328.edgefcs.net:1935/ondemand app=ondemand? playpath=mp4:u swfUrl=http://neulionms.vo.llnwd.net/o37/nba/player/nbatv/console.swf swfVfy=1
17:51:23 T:110682112 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
17:51:23 T:122953728 NOTICE: Creating InputStream
17:51:24 T:122953728 ERROR: RTMP_ReadPacket, failed to read RTMP packet header
17:51:24 T:122953728 ERROR: CDVDPlayer::OpenInputStream - error opening [rtmp://cp118328.edgefcs.net:1935/ondemand app=ondemand? playpath=mp4:u swfUrl=http://neulionms.vo.llnwd.net/o37/nba/player/nbatv/console.swf swfVfy=1]
17:51:24 T:122953728 NOTICE: CDVDPlayer::OnExit()
17:51:24 T:122953728 NOTICE: CDVDPlayer::OnExit() deleting input stream
17:51:25 T:110682112 NOTICE: CDVDPlayer::CloseFile()
17:51:25 T:110682112 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
17:51:25 T:110682112 NOTICE: DVDPlayer: waiting for threads to exit
17:51:25 T:110682112 NOTICE: DVDPlayer: finished waiting
this is the whole error when i try to play an NBA game
Anyone? Noone has any idea?
(2012-05-18, 23:47)doctor78 Wrote: [ -> ]Anyone? Noone has any idea?
check your login credentials (addon settings). That's the response when the user/password is wrong..
you need a NBA TV international subscription (single game ppv won't work) and access it via a non US or Latin American ip
I recommend removing the complete addon, closing xbmc, reinstalling 0.0.8 and restart xbmc once more.. sometimes xbmc does some nasty caching..
I can't even load the plugin after installing...just says script failed leaguepass.py Sad
(2012-05-21, 13:53)Peekz Wrote: [ -> ]I can't even load the plugin after installing...just says script failed leaguepass.py Sad
make sure that:
your xbmc is 11.0 Eden
you got httplib2
install via BlueCop's repo..
Is Eden absolutely required?
(2012-05-22, 00:24)Peekz Wrote: [ -> ]Is Eden absolutely required?
That's what I am using (and I can't judge the plugin's behaviour on different xbmc versions)
threatlockz got it working with OpenElec and Dharma..
(2012-05-09, 09:39)threatlockz Wrote: [ -> ]I can now confirm that 0.0.7 works flawlessly on XBMC Dharma (Openelec). Smile
I can get the add-on to load now but no games found...so getting better Smile
(2012-05-19, 09:48)robla Wrote: [ -> ]
I did ALL that.
My credentials are proper. I use them all the time with www.nba.tv. I am from Slovenia and I have international credentials.
I have reinstalled 10 times. I deleted plugin folders as well. I did everything I could think of. The video starts and stops after 1 second.
(2012-05-28, 21:50)doctor78 Wrote: [ -> ]
(2012-05-19, 09:48)robla Wrote: [ -> ][quote='doctor78' pid='1106602' dateline='1337377660']
ok, this shows that the plugin has done its job. It just creates a playback url and the playback itself is handled by xbmc libraries like the librtmp and ffmpeg.
Looks like You should get a "decent" librtmp. If You do a search on the xbmc forum You will find a lot of threads about updating the librtmp or problem with it on some platforms like atv etc.
Look here: another user with a different plugin has the 1 second only playback feature
http://forum.xbmc.org/showthread.php?tid...pid1114748
