Full Version: Xmbc crash in ftp in RC2 but not B3
HI
Many thanks to all the people involved in this great mediaplayer.
I have a problem with playing some 720p movies thru ftp in xbmc RC2. What happens is that xbmc shutts down im guessing its low memory it usually 30-60 sek in to the movie. The thing is that this does not happen in B3.
There is also no problem playing the movies thru smb share in RC2.
I have tried with several movies.
Hi have ios 4.4.4 thru seasonpass
Here are the past bins
xbmc.log for RC2 http://pastebin.com/9T03ARcN
xbmc.log for B3 http://pastebin.com/cWbv8Xvd
Syslog http://pastebin.com/qUZEUxji
There is no crashreport log generated in private/var/mobile/Library/Logs/CrashReporter but i found a LowMemory-2012-03-06-151929.plist generated in private/var/Logs/crashreport here is that pastbin. http://pastebin.com/RTG6dgZR
Mediainfo http://pastebin.com/gZmGSjMc
Hope this is enough info.
/Arnold
Don't think this matters but when in files view with ftp sources a file that is bigger then 2 gig only shows 2.0 gig. Perhaps this is a limitation on ftp protocol. or just a visual error.
I hav no problem playing som of these files so probably just visual error.
Looks like the RC2 log doesn't have debug logging enabled for the profile you're using?
The problem seams to have dissapeard. Reinstalld rc 2 for a third time and now it's not crashing with my test movie. Hopfully the atv heald it self:-)
The problem with the crashes in RC2 is back. Don't know whats wrong. It workes perfect in B3.
Here are the logs. Managed to get a crashreport this time. Same movie as last time i tested with.
http://pastebin.com/KJZfxbad Crashreport
http://pastebin.com/8WHiSBX1 Debug Log
http://pastebin.com/cvuhLstk syslog
Thanks for all your help
