2017-01-23, 15:14
(2017-01-22, 20:30)pkscout Wrote: [ -> ](2017-01-22, 16:47)bitnumus Wrote: [ -> ]@pkskout I still can't get the plugin to show in the visualisations menu, so i can't enable it (its now disappeared)
I'm getting logs like this over and over for most artists, maybe its related?
http://pastebin.com/2BPNWbjf
In fact all it does it report this log every second, it creates the folder in /Artistinformation/ but doesn't put anything in there (the .nfo files), what am i missing? Also i'm seeing this:
After a fresh removal and install and restart this is how it runs:
http://pastebin.com/wmEbshhf
I decide to rule out the musicbrainz log by running picard and tagging an album, now its showing this in a loop:
15:41:27.973 T:140125685188352 DEBUG: [Artist Slideshow] starting with the following artists
15:41:27.973 T:140125685188352 DEBUG: [Artist Slideshow] [u'Chris Brown']
15:41:27.974 T:140125685188352 DEBUG: [Artist Slideshow] disable multi artist is set to false
15:41:27.974 T:140125685188352 DEBUG: [Artist Slideshow] left with
15:41:27.974 T:140125685188352 DEBUG: [Artist Slideshow] [u'Chris Brown']
15:41:27.976 T:140125685188352 DEBUG: [Artist Slideshow] checking for /storage/.kodi/userdata/addon_data/script.artistslideshow/ArtistInformation/42b84ed6/
15:41:27.976 T:140125685188352 DEBUG: [Artist Slideshow] /storage/.kodi/userdata/addon_data/script.artistslideshow/ArtistInformation/42b84ed6/ exists
15:41:27.976 T:140125685188352 DEBUG: [Artist Slideshow] Looking for a musicbrainz ID for artist Chris Brown
15:41:27.976 T:140125685188352 DEBUG: [Artist Slideshow] returning c234fa42-e6a6-443e-937e-2f4b073538a3
According to the second log you posted, AS is finding images and setting the folder properly. You can tell with these lines:
Code:15:05:57.614 T:140125685188352 DEBUG: [Artist Slideshow] cached images found
15:05:57.614 T:140125685188352 DEBUG: [Artist Slideshow] ArtistSlideshow set to /storage/.kodi/userdata/addon_data/script.artistslideshow/ArtistSlideshow/42b84ed6/
15:05:57.614 T:140125685188352 DEBUG: [Artist Slideshow] ArtistSlideshow.ArtworkReady set to true
The log snippet you posted is normal when you have AS debugging enabled. That loop is part of the process that checks to see if the artist has changed (which would mean finding a new folder to show). The AS debugging info is *really* verbose, so once we're done troubleshooting, I'd definitely turn it off.
To your first comment. AS will not show in any kind of list anywhere (except in the list of Program Addons) unless the skin is doing something different than the way the default skin does it. AS is *NOT* a visualization. It is a script that sets some skin properties so that a skin can use that information to show images of the playing artist. Using my Estuary mod, I have the visualization set to NONE. Everything else is automatic if you go to the skin settings and under ARTWORK set the option for "show music visualization screen directly when playing a song" to on (it's the second option, right under "show media fanart as background." If you do that, when you hit play on an item in your music library the screen will change and you'll get images in the background.
Since you didn't post the full log, I can't tell if you're using my Estuary mod or something else. If you're not using my Estuary mod, you should check with the author of the skin you are using. From everything I can see AS is working fine.
Yes i am using your skin mod from the beta channel.
"show music visualization screen directly when playing a song" - This option is there but with no text, it was off so there is a bug. I have turned it on but it made no difference.
I have enabled text notifcations to debug some more, when i change to a new artist (i cleared the files and folders in ArtistSlideshow, to start from scratch), i receive a notification saying the images are being downloaded, and a folder is created with the artists hash.
After all this still nothing is displayed. It seems many people are reporting this same issue in one way or another, my debug log after the above process shows nothing out of the ordinary that i can see: http://pastebin.com/Hj390esT
The only error i can really find is:
13:21:22.542 T:140378773829760 DEBUG: Activating window ID: 12006
13:21:22.616 T:140378773829760 DEBUG: ------ Window Deinit (MyMusicNav.xml) ------
13:21:22.617 T:140378773829760 DEBUG: ------ Window Init (MusicVisualisation.xml) ------
13:21:22.617 T:140378773829760 INFO: Loading skin file: MusicVisualisation.xml, load type: KEEP_IN_MEMORY
13:21:22.620 T:140378773829760 ERROR: Misplaced [
13:21:22.620 T:140378773829760 ERROR: Error parsing boolean expression !System.HasAddon(script.artistslideshow) | !$INFO[Window(Visualisation).Property(ArtistSlideshow.ArtworkReady)]
13:21:22.624 T:140376501380864 DEBUG: Thread LanguageInvoker start, auto delete: false
13:21:22.625 T:140376501380864 INFO: initializing python engine.
13:21:22.625 T:140376501380864 DEBUG: CPythonInvoker(1, /storage/.kodi/addons/script.artistslideshow/default.py): start processing
