(2017-01-29, 21:37)meowmoo Wrote: [ -> ]Thanks for some reason I missed that post...so little to no chance to get proper folder names...
You are not dreaming ;P This is how it work, i have cdartManager, skin-helper and AS pointed to one folder on my NAS, and in theory its a pretty solid solution, but as I said in my previous post, ASH did not work all the time for me, and I can't figure out why...
So it appears that AS works in both directions either with "Hashed" names from the cache directory and/or the "real" names from the "local artist folder"!?
Is there a specific reason to use both CDAM and AS? From what I read they are doing the same whereas CDAM will only grab artwork for those items which are in the Kodi music database.
Yes it works both ways, you just need to setup AS correct. Like I said, I have one big folder with lots and lots of "artist art" and AS first look in this folder for fanart and only if there is nothing to use it "gos online"
CDAM download everything, artist thumb, logo, banner, cdArt, cover and fanart, AS only looking for fanart.
If you use a skin witch make use of all the art you get from fanart.TV its pretty cool
Also if you have a big collection you just need to run CDAM once and you have fanart for all you music, if its on fanart.tv, in one place and AS can make use of it without the need to download the fanart first
(2017-01-28, 18:50)pkscout Wrote: [ -> ] (2017-01-28, 15:00)Rouzax Wrote: [ -> ]Would it be an idea to have the option to use Google and Flickr?
I know that it would not be a sure fire result but to be honest I would prefer anything above an empty screen
Neither Google nor Flickr have an API for image search. If you want to search those sites manually and download the images, that would certainly work. As to something versus nothing, I think it's much better to return actual images of the artist than random images that might be the artist.
I think that both have that.
Custom Search JSON/Atom API
The JSON/Atom Custom Search API lets you develop websites and applications to retrieve and display search results from Google Custom Search programmatically. With this API, you can use RESTful requests to get either web search or image search results in JSON or Atom format.
flickr.photos.search
Return a list of photos matching some criteria. Only photos visible to the calling user will be returned. To return private or semi-private photos, the caller must be authenticated with 'read' permissions, and have permission to view the photos. Unauthenticated calls will only return public photos.
(2017-02-01, 16:08)Rouzax Wrote: [ -> ]I think that both have that.
Thanks for those. Here are my thoughts after spending some time with both. To set expectations, I believe AS should almost 100% of the time return the correct artist's images at a reasonable quality with an option to restrict them to 16x9 images.
With Flickr I can give you decent quality images and figure out the right aspect ratio, but there is no guarantee you will get an image of the actual artist. Meatloaf is my prime example. I did an API search with that, and none of the top 100 results were of the artist Meatloaf. They were of, well, meatloaf. Even using Billy Joel, most of the first 100 results were crappy, low quality images. Given that, Flickr is out in my opinion.
With Google, I would have to get an API key using my personal account at which point it would be limited to 100 queries per day with additional queries costing $5/1000 queries. That's a deal breaker. I'm not going to have AS use an API that can only do 100 global queries per day, and I'm not spending $5/1000 to buy queries. I suspect Google is going to give similarly crappy results (as far as AS is concerned), so that one is also out.
Folks, seriously, if every one that used AS gave $2 a month ($1 to theaudiodb and $1 to fanart.tv), this problem of availability would be solved many times over. So again I beg you to please pay to support the high quality sites that make AS possible.
For info, the TheAudioDB API is back online and pushing data
Im curious, whats the bandwidth limit for theaudiodb?
(2017-02-02, 14:11)meowmoo Wrote: [ -> ]Im curious, whats the bandwidth limit for theaudiodb?
3TB a month is the limit on my co-location hosting before I have to pay excess fees.
So about 100GB a day transfer. Mostly its the music fanart.
Bear in mind we also use CloudFlare so real usage is more like 12TB a month. Luckily their free tier is still working well
Wow and you run out of bandwidth last month...that's lots of downloaded fanart.
(2017-02-02, 14:42)meowmoo Wrote: [ -> ]Wow and you run out of bandwidth last month...that's lots of downloaded fanart.
If you think thats impressive, you should see what
http://fanart.tv push each month
I guess a lot more
But fanart.tv provide movie/TV shows and music..and I guess its more common than audiodb?
Well, after spending a week or so of hours here and there trying to get this working flawlessly i'm out of luck and patience!
Is AS the only option for showing fanart?
(2017-02-02, 18:20)bitnumus Wrote: [ -> ]Well, after spending a week or so of hours here and there trying to get this working flawlessly i'm out of luck and patience!
Try once more the following: Install Nebula Skin, while playing Music press "Tab" then "Enter" which should bring an OSD on the upper border of the screen. Then press the sign with the "head".
(2017-02-02, 18:46)hoschilo Wrote: [ -> ] (2017-02-02, 18:20)bitnumus Wrote: [ -> ]Well, after spending a week or so of hours here and there trying to get this working flawlessly i'm out of luck and patience!
So you think its pkscouts skin mod being the issue? i'll test this shortly, but i want to use the default skin really!
Nebula isn't on 17 repo. I am using the modified skin by pkscout
EDIT: So, i've taken a screen recording to show the issue as clearly nobody understands what i mean! You'll see the artist image flash when i click "next" track after the artist "Talib Kweli". This only happens for some artists, yes there are a few here that don't even have art, but it happens with lots of artists that do, and you can see their art flash up (its in the ArtistSlideshow folder)
Two examples:
https://sendvid.com/pfkmn6s0
https://sendvid.com/9m673h94
(2017-02-03, 11:37)bitnumus Wrote: [ -> ] (2017-02-02, 18:46)hoschilo Wrote: [ -> ] (2017-02-02, 18:20)bitnumus Wrote: [ -> ]Well, after spending a week or so of hours here and there trying to get this working flawlessly i'm out of luck and patience!
Two examples:
Sorry forget what posted about "Nebula", I did not got the whole story. I tried with 2Pac and AS is working as expected, for Kanu - no fanart shows up - it appears that there is no fanart available on Fanart.TV (you can check this by yourself with the MBID for the artists you don't get fanart). Posting log file (do not forget enable debug log in AS settings) would help to understand what is going on.
