2012-03-08, 15:43
2012-03-09, 06:21
You don't. Cache is in RAM and empties and fills as you watch video. If you get that error then it means the data coming in isn't fast enough to play without pausing. XBMC tries to buffer as much as it can in RAM, but the ATV1 has only so much RAM. It's basically saying, even though it buffered, it will have to buffer again later on.
The real issue is the slow data.
2012-03-09, 20:17
Hmm, thanks Ned.
The thing is that I checked the file transfer rate by pressing 'O' or on screen data. When I do this I see the data moving across at around 30 Mb/s. Shouldnt that be more than fast enough?
2012-03-09, 23:57
It should be. How often does the cache message pop up?
