Hi all i looked but can't seem to find how to
I'm trying to create a Playlist or Favorite from filemode is this possable
Cheers Dibsta
You can add to the favourites list using the context keyboard C command, one of the menu choices should be 'add to favourites', Using playlist, is getting your media in focus and hitting the Keyboard Q command to put the material in a playing Que, then using the 'C' command to bring menu options to playing the Que.
Smart playlists only work with library additions.
Hi ive added to favorite but when i click favorite all i get is a blank screen
Any advice
Cheers Dibsta
Hi
Here is the debug log
http://pastebin.com/Tf1rCqwg
Just to let you know if i launch favorite from favorite list it works fine but if i launch it from home screen mod i have a blank screen.
Cheers Dibsta
Hi anyone got any suggestions after looking a debug log
cheers Dibsta
i also have this problem i have some videos that i dont want scanned into my liabry but still want to access them, i added the location with no scapper, this shows up in file mode where i can browse and play the files fine, i saved the location as a fav and i can access it from the favs icon on the home screen (bottom left by the off switch on conflence) but when i add a fav to the main bar (this is a option on conflence mod, so this is where the problem might lie i dont know if the OP is using this skin) and click on that i just get a black screen
dibsta Wrote:Hi
Here is the debug log http://pastebin.com/Tf1rCqwg
Cheers Dibsta
Hi there. Your skin folders look to be corrupted. Try installing another skin and see if the favourites start working. You may need to delete:
C:\Users\Dibsta\AppData\Roaming\XBMC\addons\skin.moddedconfluence
and do a re-install.
Hi found problem the mod is not putting the correct path to favorite
(Mod path ActivateWindow(10025,"X:\Coles Media\")
but should be
(ActivateWindow(10025,"X:\\Coles Media\\") backslash is missing
Both quotes and backslashes need escaping (i.e. prepend another backslash).
