Full Version: New HTPC build, origen case, got some questions
Hello
So im putting together a new build
Case:
Origen AE M10 (150W PSU included - mini atx)
CPU:
AMD A-Series A6-3650 (i cant find the a6 3600 here in norway)
Memory:
4GB
SSD:
60GB samsung series 830
Now the cpu has 100w tdp, and the included psu is only 150w, when u add ram and ssd, how close am i to 150w? will it work?
also, will the a6 3650 fit in the ae m10, the measurements for the case is:
240 (w) x 106 (h) x 252mm (d) (*inc feet)
where's your motherboard?
why not buy the A6-3500?
oh forgot the motherboard its a
ASUS F1A75-I Deluxe, Socket-FM1
i found out that the m10 origen ae, supports max cooler height 80mm, will the 3650 fit?
is the a6 3500 enough good enough for 1080p, bitstream and handling heavy skins like aeon?
Heres the last revision of the build before i order. Comments are appreciated. Espcially on if this handles 1080p content fine, web streaming, and bitstream audio, also how it handles heavy skins (aeon etc)
MB:
CPU:
AMD A-Series A6-3500
MEM:
Corsair Vengeance DDR3 1600MHz 4GB CL9 Low profile
SSD:
Samsung SSD 830 Series 64GB 2.5"
CASE:
Origon AE M10 Silver
henrikyo Wrote:Espcially on if this handles 1080p content fine, web streaming, and bitstream audio, also how it handles heavy skins (aeon etc)
HD6530D will playback everything in your list, and the CPU should be able to handle most skins....
