2012-03-09, 16:30
I have a Zotac box hooked up through a Pioneer surround sound displaying on 1080p Philips 42" TV. As per many posts, in order to have playback as smooth as possible I've enabled the setting under the Video - Playback menu to 'Adjust the display refresh rate to match video'.
When playing SD and 720p encoded movie files the TV will be switched to 1080i mode - it's still full screen (no borders suddenly appear). Is this the expected behaviour?
Previously I had a PS3 hooked up and simply delivered movie files through PS3mediaserver or mediatomb, and this didn't require changing the TV display format. I realise this is probably completely unrelated as there is a lot more going on with xbmc, but my knowledge of all things display related and movie file encoding (e.g. fps) is pretty slim.
Some advice would be appreciated.
As another question, with an nVidia GPU, it is obviously recommended to enable VDPAU, however, should VAAPI also be enabled in the Video - Paayback section?
Also, under System - Video Output, what is LCD/VFD?
I expect I'm demonstrating my general multimedia ignorance with the above though
