Just copy all that and paste it at Pastebin.com and posts the link instead of pasting it here on the forums. Keeps it's cleaner and easier to read
Stunning looking script. Installed perfectly however no songs play. The script returns either "One or more items has failed to play. Check the log file for details." Or "Playlist - Can't find a next item to play". It seems a few of us are having this problem.
Lovely work so far and can't wait for this to be up and running! +1 for getting yatse working with it and for playing music out of the script.
Log File:
http://pastebin.com/X2v5k5eL
EDIT: Forgot to say that I had Windows Firewall & my Antivirus both disabled. Windows 7 SP1.
After updating to 12.1 my Spotimc does not plays tracks anymore either.
It logs the following on each try:
07:37:38 T:140396682921856 WARNING: FillBuffer: curl failed with code 22
07:37:38 T:140396682921856 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
07:37:38 T:140396682921856 ERROR: Open - failed to open source <http://192.168.178.25:8082/track/0livsqjO8vXZDLj4RSIa5i.wav?idx=1|X-Spotify-Token=a7891b0c71b5
6a87e2e662f97b29446e5d7d7c7a&User-Agent=Spotimc%2F1.0-beta3+%28XBMC%2F12.1+Git%3AUnknown%29>
07:37:38 T:140396682921856 ERROR: Init: Error opening file
http://192.168.178.25:8082/track/0livsqj...c71b56a87e
07:37:38 T:140394545272576 NOTICE: 192.168.178.25 - - [20/Mar/2013:07:37:38] "GET /track/0livsqjO8vXZDLj4RSIa5i.wav?idx=1 HTTP/1.1" 416 - "" "Spotimc/1.0-beta3
(XBMC/12.1 Git:Unknown)"
Same goes for OpenELEC RC5...
My spotimc addon refuses to play any tracks (it used to work until a few days ago). I have tried removing and reinstalling the addon but with no luck. I'm running Frodo on Ubuntu 12.10. Excerpt from logs here
10:27:05 T:140201575073664 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
10:27:05 T:140201575073664 ERROR: Open - failed to open source <http://10.0.1.33:8080/track/4EVWwbJhnHtg46rfV9npBX.wav?idx=0|X-Spotify-Token=067fde4a21e6b1c61833729265a2b6f0e3ed0649&User-Agent=Spotimc%2F1.0-beta3+%28XBMC%2F12.1+Git%3A0d373cc%29>
10:27:05 T:140201575073664 ERROR: Init: Error opening file
http://10.0.1.33:8080/track/4EVWwbJhnHtg...0d373cc%29
Full logs here -
http://pastebin.com/FQypTJS6.
Yup i also have the issue.
I can't wait for the new build
SOLVED
When I was starting Spotimc for the first time since upgrading Eden to Frodo 12.1 on Linux I got a splash screen saying something about a skin update. I pressed yes. After the update I can't start XBMC anymore. It just shows the background image and the X-mouse pointer and then crashes out.
Any ideas what this might be?
Turns it somehow XBMC started reacting to "wins" in nsswitch.conf. Had worked fine for years before. Strange but nvm
Still works for me on Xbmcbuntu 12.0. Shouldn't it?
Update: Forget it. It only affects 12.1 it seems.
mazkolain - I just wanted say thanks for all your continued hard work on this project once it is up and running in it's final release it is going to be awesome. I will be donating also.
I compiled PySpotifyCtypesProxy.egg from the modified source by mazkolain and now have SpotiMC working on XBMC 12.1
If you are adventurous and can't wait for the next official addon release version you can download it and overwrite the version that you have on your system.
Make sure you restart XBMC after doing this (or have XBMC stopped when you replace the file) otherwise it will not work.
1) Download the compiled egg here: removed, there is a beta4 out now !
2) Put the file you downloaded here: %APPDATA%\XBMC\addons\script.audio.spotimc\resources\libs\ overwriting the file that was present.
3) Restart XBMC
you can download it
When I download it as zip, this is not complete, or do you mean, download the official one (1.0 beta 3) and overwrtite?
I think you loaded the page just before I edited my incomplete comment - check the full explanation above.
I have edited the explanation to be even more clear.
Great app but the beta 3 no longer works with Openelec 3.0.
