2012-03-10, 03:50
Is there any way I can determine that my plugin is being called as a result of the user selecting the "R. Slideshow" button from the skin?
I need to know because I currently set default view modes based on where the user is in the plugin hierarchy. I realize I probably shouldn't be doing this, but if you used the plugin, you'd see why it's tremendously helpful to have default views for each folder (see this ticket).
I've tried everything I can think of, but it appears that from the plugin's perspective, the user is simply clicking through every folder.
Would it maybe be possible for the "R. Slideshow" button to set some property I can check, so I know the plugin is being called programmatically and not by the user? Or is there something already set I can look for?
-j
-j
