2012-03-10, 21:28
2012-03-10, 21:28
2012-03-13, 02:40
I noticed that to get Confluence to show the Bluray or HDDVD logo I had to have that in the filename e.g. Jumanji - Bluray.mkv. Try that on one and readd the movie to your library and see if that works.
2012-03-13, 05:35
Select BD/DVD Cases
2012-03-13, 11:31
(2012-03-13, 02:40)Projectzero Wrote: [ -> ]I noticed that to get Confluence to show the Bluray or HDDVD logo I had to have that in the filename e.g. Jumanji - Bluray.mkv. Try that on one and readd the movie to your library and see if that works.
Thank you, that worked well. Also found out other tags: 3DBD (3D Bluray) and DVD.
2012-03-13, 12:36
(2012-03-13, 11:31)aur0n Wrote: [ -> ](2012-03-13, 02:40)Projectzero Wrote: [ -> ]I noticed that to get Confluence to show the Bluray or HDDVD logo I had to have that in the filename e.g. Jumanji - Bluray.mkv. Try that on one and readd the movie to your library and see if that works.
Hi
How did you manage to get it to work? And which skin are you using?
I tried it on Confluence, but it didn't give me the option to select cases.
Your help is appreciated.
Wiggo
2012-03-13, 13:41
sorry to hijack your thread but I just upgraded to RC2, everything is fine but when I imported my library after a fresh install it didn't use any of the fanart for my movies/tv shows?
