Full Version: How do I properly tag this?
Hello everyone,
I have a movie that is spanned across two disks. themoviedb has the correct information for the DVD, but I am curious how I should mark it in my Movies library to indicate disk 1 and disk 2 or have my files named so when I scrape my library it XBMC works its magic... Does XBMC have an option where you click on the DVD and then it pops up a submenu to select disk 1 or 2, or how does XBMC handle something like this?
Thanks for any ideas in advance!
bl0b
Update: I see by default XBMC does what is called a "Stack". It setups a single entry in the Movies section of your library, and then points to a folder and "stacks" whatever files you have for each disk; essentially making one big movie.
While this is pretty sweet, is there anyway to tell XBMC to jump right to disk two without having to seek through the chapters?
bl0b
