2012-03-12, 20:29
Hey Guys,
I have a slight issue. Im trying to setup Anime.
I have under Video, Movies and TV Shows.
Both using their respective scrapers.
I then added a new source, for Anime, under TV shows scraper options I downloaded Anime.db scraper, and added it.
It found my anime, eg Bleach.
But its showing under TV Shows, shortcut on Aeon MQ3.
Besides showing under TV Shows, it is also NOT using absolute numbering.
So its showing as a mess. Is there any way to get it to use absolute numbering, and also be separate from TV shows?
Thats the first part.
Now in MQ3 you can add favourites to your home screen, so I created a new one called Anime, but I cannot find the favourites script it refers to, to make my Anime a favourite on the home screen. I have made Anime a favourite, but the shortcut I named goes nowhere.
Do you know where I can find the favourites script?
So ye, Anime separate from TV shows, and using Absolute numbering
And favourites script to add Anime as a link on my home screen.
Thanks guys if you can help.
