Full Version: How to switch to other skins??
How is someone supposed to switch skins in XBMC? It seems like all I can do is download/install/enable or delete a skin. I want to switch back from Xeebo to Confluence. Xeebo is the skin currently enabled. When I go into Add-Ons -> Skins, the options for disabling or uninstalling the skins are greyed out. Help?
(Using Eden RC2 + Windows 7)
settings-> appearance -> and there you can select your skin
