Firstly, thank you so much for the help. I'm running XBMC on windows. I copied the file as you had written it. It does not show the weather however, only the time and the RSS feeds down the bottom. Is there something I'm overlooking?
(2013-02-22, 00:10)kahenya Wrote: [ -> ]Hi,
This was a lifesaver, but here is a tiny trick quesion. What if I want it to show during specific times? Or every x minutes?
http://pastebin.com/XRdwAbbW
Not tested. RSS should become visible at the first seconds of playback, and go out at 10th.
Couple of things, i guess the window code is from Eden version since all the PVR stuff is missing, and there's no HomeButtonsBack.png included with Frodo version of Confluence, so replace it with one of these images
https://github.com/xbmc/xbmc/tree/Frodo/...ence/media
Hi all, I'm also interessed in this configuration but last pastebin is empty. Can someone repost it please? Thanks in advance.
i Mad Max
I am Running XBMC Gotham - How can I put the RSS feed on top of the Playing Video Like a news Ticker,
thankyou.
Simon
(2013-02-22, 10:34)mad-max Wrote: [ -> ]Need to check if you can set a visible condition based on playback time or system time
Hello Mad-Max,
I have a new question, everyting is working fine on the newest Raspberry PI, only no matter what kind
of skin i use, the rss feed is stuttering/lagging. Any idea how to fix that?
