2012-03-15, 08:22
I'm currently on Dharma (v10.1) installed on Ubuntu Lucid Lynx. I've been trying to upgrade to Eden RC2 (using the commands below) and keep getting an error on the actual install command.
The following error keeps coming up when I run any install command, even for any other package.
When I try run "sudo apt-get -f install" as suggested I get the following error. Appreciate if someone could help me out here as I seem to be a bit stuck on this. No luck in any existing forum posts. recently upgraded from Karmic to Lucid, prior to attempting the XBMC upgrade.
sudo add-apt-repository ppa:team-xbmc/unstable
sudo apt-get update
sudo apt-get install xbmc
sudo reboot
xbmc@ODIN:~$ sudo apt-get install xbmc
Reading package lists... Done
Building dependency tree
Reading state information... Done
xbmc is already the newest version.
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
xbmc: Depends: xbmc-bin (>= 2:11.0~git20120229.f38655f-0ubuntu1~ppa1~lucid) but 2:10.1~ppa1~karmic is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
xbmc@ODIN:~$ sudo apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
xserver-xorg liblaunchpad-integration1 xbmc-standalone xserver-xorg-input-evdev
xserver-xorg-input-wacom nvidia-190-kernel-source xserver-xorg-input-vmmouse
xserver-xorg-input-mouse xserver-common xserver-xorg-core libwavpack1
xbmc-skin-confluence xserver-xorg-input-all xfonts-base launchpad-integration
xinit libmodplug0c2 xbmc-data x11-xkb-utils xserver-xorg-input-synaptics
libmpeg2-4 libxkbfile1
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
xbmc-bin
The following packages will be upgraded:
xbmc-bin
1 upgraded, 0 newly installed, 0 to remove and 24 not upgraded.
2 not fully installed or removed.
Need to get 0B/10.2MB of archives.
After this operation, 20.9MB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database ... 58645 files and directories currently installed.)
Preparing to replace xbmc-bin 2:10.1~ppa1~karmic (using .../xbmc-bin_2%3a11.0~git20120229.f38655f-0ubuntu1~ppa1~lucid_i386.deb) ...
Unpacking replacement xbmc-bin ...
dpkg: error processing /var/cache/apt/archives/xbmc-bin_2%3a11.0~git20120229.f38655f-0ubuntu1~ppa1~lucid_i386.deb (--unpack):
trying to overwrite '/usr/share/man/man1/xbmc-wiiremote.1.gz', which is also in package xbmc-eventclients-wiiremote 2:11.0~git20120229.f38655f-0ubuntu1~ppa1~lucid
Processing triggers for man-db ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
