Is there a way I can get a list of all my movies and what their aspect ratio is?
I just realized that a lot of my old DVDs had a choice between widescreen and fullscreen and I ripped them using full screen because nobody had a widescreen back then... now everybody has a widescreen, so I want a list of those movies so I can re-rip them.
There is no automatic way, here are some ideas:
- open the sqlite database and search there
- write a batch/shell script that uses mediainfo(.exe) to detect the aspect-ratio
- use one of the windows batch screenshot generators and then detect it using the screenshots (for example in explorer by sorting to the resolution-column)
I used the mediainfo program in linux to do it with a bash script. worked well, except sometimes it used 4:3 and sometimes it used the decimal version, so I imported the results into a spreadsheet to finish the job.
#!/bin/bash
# Aspect Ratio Lister by Kissell
# creates aspect-ratio-results.txt in $LOCATION
LOCATION="/path/to/files"
FILE_EXTENSION="avi"
if [ "$1" ]; then
LOCATION="$1"
fi
if [ ! -s "/usr/bin/mediainfo" ]; then
sudo add-apt-repository -y ppa:shiki/mediainfo
sudo apt-get -y update
sudo apt-get -y install mediainfo
fi
if [ -d "$LOCATION" ]; then
FILES=`find "$LOCATION" -maxdepth 2 -type f -name "*.$FILE_EXTENSION" |sort |sed 's: :_:g'`
for NEXT_FILE in ${FILES[@]}; do
NEXT_FILE=$(echo "$NEXT_FILE"|sed 's:_: :g')
FOLDER_NAME=${NEXT_FILE%/*}
FOLDER_NAME=$(echo "$FOLDER_NAME"|sed s:$LOCATION/::g)
ASPECT_RATIO=`/usr/bin/mediainfo "$NEXT_FILE" | awk '/Display aspect ratio/{print $5}'`
echo "\"$FOLDER_NAME\",\"$ASPECT_RATIO\""
echo "\"$FOLDER_NAME\",\"$ASPECT_RATIO\"" >> "$LOCATION"/aspect-ratio-results.txt
done
else
echo "Directory does not exist: $LOCATION"
fi
Well done
So then good luck with your "re-rip script"
