Full Version: xbmc don't see other connected hdd
hi, i have installed xbmc on my hdd using the live cd.
it works perfect.
che command ubuntu command "hwinfo" show me all hdd correctly.
but when i run xbmc, if i try to add a new media source, i see only the hdd where is installed xbmc.
i have 2other hdd, 1 sata & 1 ide, and xbmc cant' see them.
Can i solve this problem?
best regards
UP
please help me
The disk are not automatically mounted in the OS. You need to take care of that. search for "xbmc removing nodiskmount" or "mount disk fstab ubuntu" and you should find something. The reason you didn't get an answer is probably that is has been asked and answered 1000 times already.
BTW: it is seen as bad form to bump within 24 hours.
