2012-03-15, 22:50
2012-03-15, 22:50
2012-03-15, 23:28
woa, looks like a big HTPC,
2012-03-16, 00:24
GT430+i3 is a powerful HTPC...you might want to keep it off the carpet though!
2012-03-16, 04:30
Nice pics
2012-03-16, 06:56
+1 thanks for sharing pics. Nice htpc/setup!
2012-03-16, 19:02
You might want to tuck that usb drive inside the case if you can
2012-03-21, 15:58
(2012-03-16, 00:24)bluray Wrote: [ -> ]GT430+i3 is a powerful HTPC...you might want to keep it off the carpet though!
Why? I don't think it would run that hot would it? It has 3 case fans and I thought the i3 was pretty low power/heat. I have a small table I could put it on but I thought it would be better on the floor.
As for the dongle, that's for my diNovo mini. I don't know how I'd put it inside the case but wouldn't that cut down on reception?
2012-03-21, 16:17
(2012-03-21, 15:58)patseguin Wrote: [ -> ]It is not really heat issue. Placing the PC and electronics directly on the carpet is not a good idea, it tend to collect dust very fast.....(2012-03-16, 00:24)bluray Wrote: [ -> ]GT430+i3 is a powerful HTPC...you might want to keep it off the carpet though!
(2012-03-21, 15:58)patseguin Wrote: [ -> ]As for the dongle, that's for my diNovo mini. I don't know how I'd put it inside the case but wouldn't that cut down on reception?That is what I thought. You have better wireless reception by having it outside/in-front the case.....
