2012-03-16, 08:22
Was working on this today as Ive never done it and managed to do everything until I reached terminal on my windows with PuTTy and Ive ran the command
it appears to run through but every file gives me an "operation Not Permitted" problem like so...
the addons are in XBMC but none of them appear to be working, some do but Sportsdevil for example wont find any content when on the other ATV I copied this from it was working fine, has anyone ran into this problem before? Ive tried a few things like CHMOD all fill in the XBMC folder to 777 (not sure if thats a good idea).
Im not sure what to login to with putty, Ive used mobile with alpine as the password (which gave me this), Ive tried logging in as root but when I run the command nothing happens it just skips to the next line in PuTTy.
Any help or advice would be greatly appreciated
chown -R mobile.mobile /var/mobile/Library/Preferences/XBMC
chown: changing ownership of `/var/mobile/Library/Preferences/XBMC': Operation not permitted
