Full Version: Change alsa master volume with a remote control and give visual feedback
This was born due to a lack to control volume when launching external program from within xbmc. The external program uses the alsa master volume and not the internal xbmc volume and if you have an xbmc appliance and you controls it just with a remote, this is a problem.
Prerequisite: aosd-cat and lirc
$ sudo apt-get install aosd-cat
$ sudo apt-get install lirc
for ubuntu systems.
The bash script:
#!/bin/bash
# parameter: <value>- or <value>+ or <value>
die () {
    echo >&2 "$@"
    exit 1
[ "$#" -eq 1 ] || die -e "\n1 argument required, $# provided.\n\nUsage:\n$0 1+     # increase alsa Master volume by 1 unit\n$0 2dB+   # increase alsa Master volume by 2 dB\n$0 10-    # decrease alsa Master volume by 10 units\n$0 50     # set alsa Master volume to 50\n"
u=1000
o=350
e=1
R=green
b=0
B=black
DISPLAY=:0.0 # primary display
AMIXER_CMD=/usr/bin/amixer
KILL_CMD=/usr/bin/killall
$AMIXER_CMD -q -c 0 sset Master,0 $1 2>/dev/null
$KILL_CMD aosd_cat &> /dev/null
CURR_VOLUME=`$AMIXER_CMD get Master 2>/dev/null | grep 'Mono:' | sed -e 's/^[^\[]*//' -e 's/^.//' -e 's/%.*$//'`
if [ "$CURR_VOLUME" != "0" ]
then
        echo $CURR_VOLUME |DISPLAY=$DISPLAY aosd_cat -n "Arial Black 18" -u $u -o $o -R $R -S none -f 0 -y -10 -e $e -b $b -B $B -t 0 -d 5 &
else
        echo "Mute" |DISPLAY=$DISPLAY aosd_cat -n "Arial Black 18" -u $u -o $o -R red -S none -f 0 -y -10 -e $e -b $b -B $B -d 5 -t 0&
fi
eventually made changes to fit your needs, save it into a new change_volume.sh file and make it executable:
$ chmod ugo+x ./change_volume.sh
To check that everything is going well, test the script with:
$ ./change_volume 10-
You should hear the sound lower down and its value on the screen (a very small and elegant bottom left corner green value).
Now edit your .lircrc and put this at bottom:
begin
        prog = irexec
        remote=devinput
        button = KEY_ZOOM
        config = ~/.xbmc/system/change_volume.sh 1+
        repeat = 1
end
begin
        prog = irexec
        remote=devinput
        button = KEY_MEDIA
        config = ~/.xbmc/system/change_volume.sh 1-
        repeat = 1
end
Where I've placed the change_volume.sh script into ~/.xbmc/system/ folder and mapped the actions to the lirc buttons KEY_ZOOM (volume up) and KEY_MEDIA (volume down).
Finally start irexec ad daemon:
$ irexec -d
to run the change_volume.sh script when the remote control buttons are pressed.
If you wants irexec at boot time, put this line inat the end of the /etc/rc.local file:
su xbmc -c "irexec -d > /dev/null 2>&1"
Hope this can be useful for someone.
First i have to say Great code, its works very well.
I have done some changes because of some issues i having.
1- this code get every display in use and send osd to all
2- my amixer dont work without the -c0
3- my system wont unmute without the on off fix
4- the transparence set to 0 give me some artifacts
5- the kill -9 seens to make the screen freeze less
6- the mute stay on screen until unmuted
TODO:
Avoid toggle using set volume to 0 and them recover from a file
Stop all screen freeze
Add option to enable/disable volume as a bar
PS:
Use mudo as argument to mute and unmute
#!/bin/bash
#echo 2>&1 > ~/logvol.log
die () {
    echo >&2 "$@"
    exit 1
u=1000
o=350
e=1
R=green
b=0
B=black
p=0
t=1
CONTROL=Master
DISPLAY=$(/bin/ps aux | grep xinit | egrep -ow ':[0-9] -auth|-- :[0-9]'| sed -e 's/ -auth//g'| sed -e 's/-- //g')
AMIXER_PARAM=-c0
KILL_CMD=/bin/kill
PIDOF=/bin/pidof
if [ "$1" == "mudo" ]
then
$AMIXER_CMD $AMIXER_PARAM set $CONTROL toggle
$KILL_CMD -9 $($PIDOF aosd_cat) &> /dev/null
MUTESTATUS=$($AMIXER_CMD $AMIXER_PARAM get $CONTROL | egrep -w 'off|on' |  awk '{print $6}' | tr -d '[]')
if [ "$MUTESTATUS" == "off" ]
then
for i in $DISPLAY
do
echo "Mute" |DISPLAY=$i aosd_cat -n "Arial Black 23" -u $u -o 1234567890 -R red -S none -f 0 -y -10 -e $e -b $b -B $B -d 5 -t $t -p $p &
done
elif [ "$MUTESTATUS" = "on" ]
then
$AMIXER_CMD $AMIXER_PARAM set Speaker off
$AMIXER_CMD $AMIXER_PARAM set Speaker on
$AMIXER_CMD $AMIXER_PARAM set Headphone off
$AMIXER_CMD $AMIXER_PARAM set Headphone on
fi
else
$AMIXER_CMD -q $AMIXER_PARAM sset $CONTROL,0 $1 2>/dev/null
CURR_VOLUME=`$AMIXER_CMD $AMIXER_PARAM get $CONTROL 2>/dev/null | grep 'Mono:' | sed -e 's/^[^\[]*//' -e 's/^.//' -e 's/%.*$//'`
then
for i in $DISPLAY
do
        echo $CURR_VOLUME |DISPLAY=$i aosd_cat -n "Arial Black 23" -u $u -o $o -R $R -S none -f 0 -y -10 -e $e -b $b -B $B -t $t -d 5 -p $p  &
done
else
for i in $DISPLAY
do
        echo "Mute" |DISPLAY=$i aosd_cat -n "Arial Black 23" -u $u -o $o -R red -S none -f 0 -y -10 -e $e -b $b -B $B -d 5 -t $t -p $p &
done
fi
fi
some improvements
#!/bin/bash
#Script based on the code of joethefox http://forum.xbmc.org/archive/index.php/thread-125797.html
#Rewrited by ochiman
#PS: The code for the bar is lame, if someone know one good code please update this script
die () {
    echo >&2 "$@"
    exit 1
[ "$#" -eq 1 ] || die -e "\n1 argument required, $# provided.\n\nUsage:\n$0 1+     # increase alsa Master volume by 1 unit\n$0 2dB+   # increase alsa Master volume by 2 dB\n$0 10-    # decrease alsa Master volume by 10 units\n$0 50     # set alsa Master volume to 50\n$0 mudo   # set alsa Master to mute\n"
#AOSD_CAT Options, change whatever you want
FADEFULLOPACITY="1000"
FADEOUT="350"
SHADOWOFFSET="0"
FORECOLOR="green"
BACKGROUNDOPACITY="0"
BACKCOLOR="black"
POSITION="0"
POSITIONBAR="6"
TRANSPARENCE="0" # 0 to none | 1 to fake | 2 to composite
FONT="Arial Black 30"
FONTBAR="Arial Black 20"
#Mute options
FADEOUTMUTE="123456789"
FORECOLORMUTE="red"
#System Configuration
CONTROL="Master" # Can be used as PCM
AMIXER_PARAM="-c0" # Set to -D "your sound hardware" if you have some issue
BAR="1" #Active progress bar
TEXT="1" #Active Text mode
#For use of script, do not change unless you know what you are doing
DISPLAY=$(/bin/ps aux | egrep 'xinit|Xorg' | egrep -ow ':[0-9] -auth|-- :[0-9]|:0 -background'| sed -e 's/ -auth//g' -e 's/-- //g' -e 's/ -background//g') # Locate every open Display
MUTESTATUS=`amixer $AMIXER_PARAM get $CONTROL  | grep 'Mono:' | sed -e 's/^[^\[]*//' -e 's/^.//' -e 's/].*$//'` #Get the % to restore later
#Begin of code
    #Mute
then
    while [ "$(pidof aosd_cat)" != "" ] ; do #This is because i am neurotic
    kill -9 $(pidof aosd_cat)
    done
    if [ "$MUTESTATUS" != "0%" ]
    then
        amixer -q $AMIXER_PARAM sset $CONTROL,0 0
        echo $MUTESTATUS > ~/lastvol
            if [ "$TEXT" == "1" ]
            then
                for i in $DISPLAY
                do
                    echo "MUTE" | DISPLAY=$i /usr/bin/aosd_cat -n "$FONT" -u $FADEFULLOPACITY -S none -f 0 -y -10 -e $SHADOWOFFSET -b $BACKGROUNDOPACITY -B $BACKCOLOR -t $TRANSPARENCE -d 5 -R $FORECOLORMUTE -o $FADEOUTMUTE -p $POSITION &
                    echo $AOSD
                done
            fi
            if [ "$BAR" == "1" ]
            then
                for i in $DISPLAY
                do
                    alvo="0"
                    z=""
                    while [ $alvo -lt "100" ]
                    do
                    z="$z-"
                    alvo=$[$alvo+1]
                    done
                    echo $z | DISPLAY=$i /usr/bin/aosd_cat -n "$FONTBAR" -u $FADEFULLOPACITY -S none -f 0 -y -10 -e $SHADOWOFFSET -b $BACKGROUNDOPACITY -B $BACKCOLOR -t $TRANSPARENCE -d 5  -R $FORECOLORMUTE -o $FADEOUTMUTE -p $POSITIONBAR &
                done
            fi
    elif [ "$MUTESTATUS" == "0%" ]
    then
        file=$(ls ~/lastvol)
        if [ -f "$file" ]
        then
            LASTVOL=$(cat ~/lastvol)
            rm ~/lastvol
            amixer -q $AMIXER_PARAM sset $CONTROL,0 $LASTVOL
            CURR_VOLUME="$(echo $LASTVOL | sed -e 's/%//')"
                    then
                        for i in $DISPLAY
                        do
                            echo $CURR_VOLUME | DISPLAY=$i /usr/bin/aosd_cat -n "$FONT" -u $FADEFULLOPACITY -S none -f 0 -y -10 -e $SHADOWOFFSET -b $BACKGROUNDOPACITY -B $BACKCOLOR -t $TRANSPARENCE -d 5 -R $FORECOLOR -o $FADEOUT -p $POSITION &
                        done
                    fi
                    then
                        for i in $DISPLAY
                        do
                            alvo=$CURR_VOLUME
                            z=""
                            l="0"
                            while [ $l -lt $alvo ]
                            do
                            z="$z+"
                            l=$[$l+1]
                            done
                            do
                            z="$z-"
                            alvo=$[$alvo+1]
                            done
                            echo $z | DISPLAY=$i /usr/bin/aosd_cat -n "$FONTBAR" -u $FADEFULLOPACITY -S none -f 0 -y -10 -e $SHADOWOFFSET -b $BACKGROUNDOPACITY -B $BACKCOLOR -t $TRANSPARENCE -d 5 -p $POSITIONBAR &
                        done
                    fi
        fi
    fi
    #Volume Control
else
    #Check if is Muted and unmute before change volume
    if [ -s "$file" ]
    then
    rm ~/lastvol
    fi
    amixer -q $AMIXER_PARAM sset $CONTROL,0 $1
    CURR_VOLUME=$(amixer $AMIXER_PARAM get $CONTROL  | grep 'Mono:' | sed -e 's/^[^\[]*//' -e 's/^.//' -e 's/%.*$//')
        done
    then
            then
                for i in $DISPLAY
                do
                done
            fi
            then
                for i in $DISPLAY
                do
                    alvo=$CURR_VOLUME
                    z=""
                    l="0"
                    do
                    z="$z+"
                    l=$[$l+1]
                    done
                    do
                    z="$z-"
                    alvo=$[$alvo+1]
                    done
                    echo $z | DISPLAY=$i /usr/bin/aosd_cat -n "$FONTBAR" -u $FADEFULLOPACITY -S none -f 0 -y -10 -e $SHADOWOFFSET -b $BACKGROUNDOPACITY -B $BACKCOLOR -t $TRANSPARENCE -d 5  -R $FORECOLOR -o $FADEOUT -p $POSITIONBAR &
                done
            fi
    fi
fi
Everthing seens to be perfect
but the screen still freezes in fullscreen playback
if someone have a clue of why, please tell me
any help will be appreciated
Features:
-Displays volume bar and value simultaneous (or how user want)
-Send osd to every screen active
-Settings for volume bar and value separated
-Mute set the audio volume to 0, avoiding the issue of using toggle in some systems
PS: if you run emulator this is very useful, i put the every display for this reason.
@ochiman, great work!!! I will try your improvements asap and will test the screen freezes in fullscreen playback issue.
The issue appers to be because of this
22:44:51 T:140145185519360 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
22:45:02 T:140145185519360 WARNING: Previous line repeats 104 times.
22:45:02 T:140145185519360 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
22:45:02 T:140145185519360 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
22:48:35 T:140145185519360 WARNING: Previous line repeats 97 times.
22:48:35 T:140145185519360 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
22:48:35 T:140145185519360 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
22:48:43 T:140145185519360 WARNING: Previous line repeats 67 times.
22:48:43 T:140145185519360 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
22:48:43 T:140145185519360 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
Fixed with a line in xorg.conf
Section "Device"
Identifier "nvidia"
        Option  "NoFlip"              "true"
EndSection
Now i think it is done
-when volume is 0 mute status shows up
-better characters for volume bar (in hex values)
#!/bin/bash
die () {
    echo >&2 "$@"
    exit 1
FADEOUT="350"
SHADOWOFFSET="0"
FORECOLOR="green"
BACKCOLOR="black"
POSITION="0"
POSITIONBAR="6"
FONT="Common 30"
FONTBAR="Common 11"
#Mute options
FORECOLORMUTE="red"
AMIXER_PARAM="-c0" # Set to -D your sound hardware if you have some issue
BARFULL=$(echo -e "\\xe2\\x96\\x88\\x0a")
BAREMPTY=$(echo -e "\\xe2\\x96\\x81\\x0a")
#Begin of code
    #Mute
then
    done
    then
            then
                for i in $DISPLAY
                do
                    echo $AOSD
                done
            fi
            then
                for i in $DISPLAY
                do
                    alvo="0"
                    z=""
                    do
                    z="$z$BAREMPTY"
                    alvo=$[$alvo+1]
                    done
                done
            fi
    then
        file=$(echo ~/lastvol)
        if [ -f "$file" ]
        then
            rm ~/lastvol
                    then
                        for i in $DISPLAY
                        do
                        done
                    fi
                    then
                        for i in $DISPLAY
                        do
                            alvo=$CURR_VOLUME
                            z=""
                            l="0"
                            do
                            z="$z$BARFULL"
                            l=$[$l+1]
                            done
                            do
                            z="$z$BAREMPTY"
                            alvo=$[$alvo+1]
                            done
                        done
                    fi
        fi
    fi
    #Volume Control
else
    if [ -s "$file" ]
    then
    rm ~/lastvol
    fi
        done
    if [ "$CURR_VOLUME" == "0" ]
    then
            then
                for i in $DISPLAY
                do
                    echo $AOSD
                done
            fi
            then
                for i in $DISPLAY
                do
                    alvo="0"
                    z=""
                    do
                    z="$z$BAREMPTY"
                    alvo=$[$alvo+1]
                    done
                done
            fi
    elif [ "$CURR_VOLUME" != "0" ]
    then
            then
                for i in $DISPLAY
                do
                done
            fi
            then
                for i in $DISPLAY
                do
                    alvo=$CURR_VOLUME
                    z=""
                    l="0"
                    do
                    z="$z$BARFULL"
                    l=$[$l+1]
                    done
                    do
                    z="$z$BAREMPTY"
                    alvo=$[$alvo+1]
                    done
                    echo $z | DISPLAY=$i /usr/bin/aosd_cat -n "$FONTBAR" -u $FADEFULLOPACITY -S none -f 0 -y -10 -e $SHADOWOFFSET -b $BACKGROUNDOPACITY -B $BACKCOLOR -t $TRANSPARENCE -d 5  -R $FORECOLOR -o $FADEOUT -p $POSITIONBAR -e 0 &
                done
            fi
    fi
fi
thanks for the support
if you have some issue with the script, please let me know
