2012-03-18, 04:25
Pages: 1 2
2012-03-18, 04:37
while playing a video you can call the video settings and disable the subtitles and then do "apply to all"
2012-03-18, 04:39
(2012-03-18, 04:37)Martijn Wrote: [ -> ]while playing a video you can call the video settings and disable the subtitles and then do "apply to all"
How do I get into the video setting, I pressed M and nothing happens?
2012-03-18, 04:42
or hit ENTER
Should be the same as M
2012-03-18, 04:44
(2012-03-18, 04:42)Martijn Wrote: [ -> ]or hit ENTER
When I hit enter it just pauses the video (using Eden)
2012-03-18, 04:57
Hold the middle button on the atv remote for 5 seconds or so, then scroll right, to volume settings.
2012-03-18, 05:12
(2012-03-18, 04:57)yeroc1982 Wrote: [ -> ]Hold the middle button on the atv remote for 5 seconds or so, then scroll right, to volume settings.
I'm not using atv It's on my PC, I'm going to guess and say it must be windows 8 preview that is the problem. I will be switching back to windows 7 soon enough though.
2012-03-18, 05:25
2012-03-18, 05:34
(2012-03-18, 05:25)Jezz_X Wrote: [ -> ]press "M" to bring up the OSD (the one with play,stop,next, etc on it) then select this button off to the right
Then this window pops up and de-select "Enable Subtitles" then click "Set as default for all movies"
And if you want later you can toggle them on and off for a single movie with the S key
Stupid me I thought that was just for volume controls not subtitles, that worked thanks!
2012-03-18, 05:56
yeah its just general audio settings of which subtitles seem to fit into since its an audio replacement
2013-05-26, 15:19
Wow, im a total moron for not knowing to scroll down a little further to "Set default for all movies". Been using Frodo for a few months now, casually curious on how to disable this full time. But I do like the idea of having it enabled by default (one less thing for deaf / impaired to worry about).
2014-01-13, 13:49
Seriously, how is this not a global setting?
2014-05-21, 07:35
(2014-01-13, 13:49)bsg1 Wrote: [ -> ]Seriously, how is this not a global setting?+1
2015-06-15, 08:43
Kodi bells on Windows 8, pressing the L key turns the subtitles on and off for me.
2015-08-08, 23:46
I did everything you said, fixed that time. However, if I am watching a series...every episode I find myself toggling off these damn subtitles, what's up! do I need to reboot after?
Pages: 1 2
