Full Version: xperience1080
Has anyone had any problems with the skin xperience1080 I tested it on xbmcbuntu beta 3 and xbmc eden rc2 both had the same result every now and then I would run problem free but there was time it would freeze or take ages to change panels and also powered down myu system read more about the problems I had below
http://forum.xbmc.org/showthread.php?tid=125894
As good as xperience1080 looks for now I will stick with PM3.HD and would advice people to do the same if anyone thinks there's a better skin out there then plese post details
(2012-03-19, 02:36)l33ster Wrote: [ -> ]Has anyone had any problems with the skin xperience1080 I tested it on xbmcbuntu beta 3 and xbmc eden rc2 both had the same result every now and then I would run problem free but there was time it would freeze or take ages to change panels and also powered down myu system read more about the problems I had below
Is your period key broken? Run-on sentences like yours above are taxing to read and difficult to decipher.
Wow if there was an award for most un-useful thread......
