Full Version: Win8 Consumer Preview Startbar issue
So I am giving the Windows 8 Consumer Preview a try and I am running into a problem.
When I have xbmc playing on my other screen, whatever I do on my main screen activates the blue bar (was start bar? lol) at the bottom of the screen and covers the little bit of bottom on my second screen. Ideas?
I have to usually go back over, click and it goes away but then I go back to the other screen it comes back.
I do have the option for fullscreen instead of true fullscreen already on.
You can try the "alwaysontop" advanced setting (see Wiki). But the task bar is likely to fight with XBMC to be on top...
If you right click on the bar, go into properties, there is an option you can uncheck to show bar on multiple monitors, then it will get rid of the bar on your second screen.
