2012-03-19, 11:37
Hello,
I was just having some issues with the atv2, so I decided to use the opportunity to update my XBMC to the latest beta for testing, but it fails on com.nito.updatebegone:
atv2:~ root# apt-get update
Hit http://apt.awkwardtv.org stable Release.gpg
Ign http://mirrors.xbmc.org ./ Release.gpg
Hit http://apt.saurik.com tangelo-3.7 Release.gpg
Hit http://apt.awkwardtv.org stable/main Packages/DiffIndex
Ign http://mirrors.xbmc.org ./ Packages/DiffIndex
Ign http://apt.saurik.com tangelo-3.7/main Packages/DiffIndex
Hit http://apt.saurik.com tangelo-3.7/main Packages
Hit http://mirrors.xbmc.org ./ Packages
Reading package lists... Done
atv2:~ root# apt-get install org.xbmc.xbmc-atv2
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
org.xbmc.xbmc-atv2: Depends: com.nito.updatebegone but it is not installable
If I try installing it directly:
atv2:/etc/apt/sources.list.d root# apt-get install com.nito.updatebegone
Package com.nito.updatebegone is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package com.nito.updatebegone has no installation candidate
What repos should I be using currently? Has the repo changed for updatebegone?
Cheers,
David
Cheers,
David
