Have a W7 HTPC with XBMC on it. Looking for an easy way to stream to this phone on the same WiFi network. It is a Motorola Atrix and has an HDMI out and I want to stream to it for the bedroom. It will be mostly used by my wife, hence the "simple" request.
A uPnP client possibly? Googling for "android upnp client" seems to return a fair number of hits.
JR
Depending on what format your content is
Twonky works pretty well. If you are looking for transcoding check out
Plex. Hope that helps.
I just set a SMB share on the PC and use BSPlayer.
BSPlayer has HW accel and online subtitle fetching.
You don't to install anything on the PC just add server (IP) in BSPlayer and you're good to go.
(2012-03-20, 17:54)xbs08 Wrote: [ -> ]I just set a SMB share on the PC and use BSPlayer.
can BSPlayer handle a folder & if so do you know if it actually plays things in order or is it just random.
currently using UPnPlay with either MXvideo or QQplayer. they work great except for playing folders... everything is in some weird random order & there is no way that i can find to fix that.
