Hello,
I'm having trouble installing the Simplicity theme from within XBMC. I get an error message "Dependencies not met", but I can not find these dependencies. Can anyone help me here?
System: Ubuntu 11.10
XBMC version: 11.0 RC2
(2012-03-19, 22:16)rilorolo Wrote: [ -> ]Hello,
I have the same problem on Windows 7 x64. Coming from a Boxee Box, I'd really like to use Simplicity/Shade. Any ideas?
The debug log will tell you what the deps are that are missing (in case you don't pick it up from the notification).
(2012-03-20, 10:34)jmarshall Wrote: [ -> ]The debug log will tell you what the deps are that are missing (in case you don't pick it up from the notification).
Ahh, Xeebo left that part out. Thanks, I'll enable the debug and have a look after work.
Debug log?
Noob, sorry
(2012-03-20, 11:12)rilorolo Wrote: [ -> ] (2012-03-20, 10:34)jmarshall Wrote: [ -> ]The debug log will tell you what the deps are that are missing (in case you don't pick it up from the notification).
Debug log?
Noob, sorry
Go to Settings > System > Debugging and enable the log. Have a look
here, it tells you more about it and how you get the log.
(2012-03-20, 10:03)SeeK Wrote: [ -> ] (2012-03-19, 22:16)rilorolo Wrote: [ -> ]Hello,
(2012-03-20, 11:38)SeeK Wrote: [ -> ] (2012-03-20, 11:12)rilorolo Wrote: [ -> ] (2012-03-20, 10:34)jmarshall Wrote: [ -> ]The debug log will tell you what the deps are that are missing (in case you don't pick it up from the notification).
Debug log?
Noob, sorry
Go to Settings > System > Debugging and enable the log. Have a look here, it tells you more about it and how you get the log.
There is nothing in the log about the dependencies not met
In XBMC i go to 'add-ons' --> 'Get Add-ons' --> 'XBMC.org Add-ons' --> ' Skin'
And there it states that the Simplicity skin is 'Broken'
If I click it, there's a message 'This add-on has been marked as broken in the repository'
And there is nothing in the log....
(2012-03-20, 20:34)rilorolo Wrote: [ -> ] (2012-03-20, 11:38)SeeK Wrote: [ -> ] (2012-03-20, 11:12)rilorolo Wrote: [ -> ]Debug log?
Noob, sorry
Thers is nothing in the log about the dependencies not met
logo-downloader is the culprit
hmm and why did that get into Eden repo
I just wanted to post that too indeed. I downloaded the skin, extracted and created a zip and tried to load it into XBMC. Then the log stated I was missing script.logo-downloader version 2.0.
When I did a search on that logo downloader I fount out is was deprecated
http://forum.xbmc.org/showthread.php?tid=74912
But you can still download it from:
http://www.mediafire.com/?qoepsah8wh1r0x5
Don't know if that's the way to go....
[EDIT]
It's not. It doesn't work.
hello there
i am getting the same error message.
is anyone working on this problem?
am i the only one who is missing this awesome skin?
i would love to help out, but unfortunately i am no coder....
please somebody help revive this skin.
thx
Please fix this
reFocus uses the logo downloader and works. Why is it a problem for Simplicity?
reFocus does not use logo-downloader but artwork downloader.
A few days ago I began getting the "Dependencies Not Met" error and almost all my add-ons are showing "broken".
After reading around on the forum, I enabled log and, sure enough, the error often appearing in log is :
14:44:35 T:2954216544 DEBUG: Addon script.common.plugin.cache requires xbmc.python version 2.1.0 which is not available
Ok...seems that xbmc.python V 2.1.0 is missing...now what ?
Can it bee repaired using only webinterface ? (I will explain why)
I am using a Raspberry Pi
