Full Version: Recently added videos not playing
I have the recently added videos on the home screen and sometimes the video does not play. The videos play fine if I go to the TV or Movie library. Anyone know why this happens?
What skin are you using?
Can you post a log-file when this happens?
mad-max
It happens with 10.1 and the new beta using the default skin. I am not sure how to post the log file The same video plays fine if I go to the library.
DVDPlayer: Opening: D:\Downloads\TV\Two and a Half Men\Season 9\Two.and.a.Half.Men.S09E19
22:50:49 T:2660 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
22:50:49 T:4068 NOTICE: Creating InputStream
22:50:49 T:4068 ERROR: CDVDPlayer::OpenInputStream - error opening [D:\Downloads\TV\Two and a Half Men\Season 9\Two.and.a.Half.Men.S09E19
22:50:49 T:4068 NOTICE: CDVDPlayer::OnExit()
22:50:49 T:4068 NOTICE: CDVDPlayer::OnExit() deleting input stream
22:50:49 T:2660 ERROR: XBMC.PlayMedia could not play media: D:\Downloads\TV\Two and a Half Men\Season 9\Two.and.a.Half.Men.S09E19
22:50:49 T:2660 NOTICE: CDVDPlayer::CloseFile()
22:50:49 T:2660 NOTICE: DVDPlayer: waiting for threads to exit
22:50:49 T:2660 NOTICE: DVDPlayer: finished waiting
22:50:54 T:2660 NOTICE: DVDPlayer: Opening: D:\Downloads\TV\Two and a Half Men\Season 9\Two.and.a.Half.Men.S09E19.Palmdale
22:50:54 T:2660 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
22:50:54 T:5024 NOTICE: Creating InputStream
22:50:54 T:5024 ERROR: CDVDPlayer::OpenInputStream - error opening [D:\Downloads\TV\Two and a Half Men\Season 9\Two.and.a.Half.Men.S09E19]
22:50:54 T:5024 NOTICE: CDVDPlayer::OnExit()
22:50:54 T:5024 NOTICE: CDVDPlayer::OnExit() deleting input stream
22:50:54 T:2660 ERROR: XBMC.PlayMedia could not play media: D:\Downloads\TV\Two and a Half Men\Season 9\Two.and.a.Half.Men.S09E19
22:50:54 T:2660 NOTICE: CDVDPlayer::CloseFile()
22:50:54 T:2660 NOTICE: DVDPlayer: waiting for threads to exit
22:50:54 T:2660 NOTICE: DVDPlayer: finished waiting
Best way to post a log is pastebin.com
And it would be good to have a complete log and not only an extract...
mad-max
(2012-03-21, 04:56)rasstar Wrote: [ -> ]It happens with 10.1 and the new beta using the default skin. I am not sure how to post the log file The same video plays fine if I go to the library.
Enable debug logging from System settings, System, Debugging, and restart XBMC then wait a minute or two for all the startup tasks to finish. Now try to play a video from Recently added, and when it fails close XBMC.
Open the debug log by pressing Windows-R and in the Run dialog type:
"%appdata%\xbmc\xbmc.log"
(including the quotes). Click OK and the log should open in Notepad. Copy and paste the log into http://pastebin.com/ and post the link it gives you here.
JR
This is the log. http://pastebin.com/XmP7EMu4
The shows that failed are The River s01e08 and Two and a Half Men s09e19. The play fine if I go to the library.
It's because of the comma's in the paths. This has been fixed already by the skinners afaik, so will be all good in Eden Final (just around the corner...)
It also happened in 10.1. I guess that was the problem. Thanks.
Hello. I am trying to play a "favourited" radio station, and it does not work. When going through music>addons>etc the radio station plays just fine. Could anyone help me with it as I am quite new to XBMC. The log is here http://pastebin.com/PtBCH2mW Thanks!
(2012-10-06, 16:39)vytisk Wrote: [ -> ]Hello. I am trying to play a "favourited" radio station, and it does not work. When going through music>addons>etc the radio station plays just fine. Could anyone help me with it as I am quite new to XBMC. The log is here http://pastebin.com/PtBCH2mW Thanks!
I replied to you in your other post: http://forum.xbmc.org/showthread.php?tid...pid1222673
