Full Version: Playback problem - Video fast play 10 seconds audio out of sync
Im new to the forum and to XBMC so I hope this post is correct.
4.4.4 ATV2
XBMC 11.0-RC1 Git:20120226-30312f1 (compiled : Feb 26 2012)
installed with NitoTV
Recently I been having problems with playing video both xvid videos from my computer and flash streams from other hosts. At first I just did a reboot and the problem was gone now the problem is consisting.
When I play a video the first 10-15 seconds of the video fast forward about 2-3x speed then the video plays at normal speed but the audio is out of sync.
Here is the debug log: http://pastebin.com/08Ffeepk
Best regards,
Oskar
You should just need to update to RC 2. RC 1 had a nasty AV sync issue. Just update via NitoTV, even if it says you already have the latest, just hit update or install and it should do it.
I had the same problem and fixed it be deleting guisettings
rm /private/var/mobile/Library/Preferences/XBMC/userdata/guisettings.xml
