DXVA2 option gone in Eden (RC2)
So I cannot enable Enable Hardware Accelerated Decoding
Can you advice how to make it avaiable ?
I have ATI Radeon HD 4250, collegue of mine has same problem with Nvidia ION
This option was avaiable on Drahma...
Go to: Settings... Video... Playback
I was saying that this option is no longer in my Eden installation
EDIT
Heard that this option is not avaiable on Windws XP, but only Windows 7 ??
(2012-03-21, 08:42)parslej Wrote: [ -> ]EDIT
Yes, Win XP doesn't support the DXVA2 interface that XBMC uses for the hardware acceleration.
JR
Quote:Yes, Win XP doesn't support the DXVA2 interface that XBMC uses for the hardware acceleration.
I was almost sure I saw it on Drahma installaiton on XP - might it be that this not applies to Eden only ?
(2012-03-21, 13:41)parslej Wrote: [ -> ]Quote:Yes, Win XP doesn't support the DXVA2 interface that XBMC uses for the hardware acceleration.
Afraid not, Windows XP has never supported DXVA2 and even when Dharma was released they mentioned that DXVA2 support was for Vista+ only (if you see the new's post at
http://xbmc.org/theuni/2010/12/18/xbmc-10-0/ you'll see they say Vista and 7 only)
Actually,XP supports DXVA2 for VC-1 and MPEG2,but better to use 7 gigi
Good to hear windows xp supports it !
Question is how to make it available now in xbmc ?
You can't unless you build your own XBMC and make some changes in the code.
