Full Version: adding only movie data
Hey,
is it possible to get a movie into the db without ripping it so if you select it, it shows you all the info and then asks you to insert the disc?
help is appreciated guys Smile
mbenner
Use .stub files - try searching the forums and wiki using google.
offline files... get your catalog of real disks inside XBMC library without any ripping!
http://wiki.xbmc.org/index.php?title=HOW...fake_files
Thank you for the help Smile
