Good morning,
i have a problem with XBMC, both dharma 10.1 and eden rc2.
both versions (the only ones i've tried) during the startup get blocked and freeze the pc, so that the only thing i could do is to force the restart of the pc.
the pc is a HP Pavilion DV6 6150sl composed by:
Intel i-5, 4gb memory
double gpu: a HD2000 integrated in the processor, and a dedicated RADEON HD 6770M. They're settled FIXED from bios so that i could use just the radeon for any process.
2 audio dirvers: intel audio display & IDT high audio definition codec
i tried in any way, but ther's no chance to make the program works (at least with my limited knowledge of pc) nor even to come to the initial menu.
could you pls give me an explaination?
thanks in advance for your kind help,
best regards
P.S.: this is the guisettings that were created by the program even if doesn't start in anyway
sorry for my baaaad english
GUISETTINGS <---- click me
does the pc work properly in general? heat problems? bluescreens?
Xp / vista/ 7?
works really great in general. brand new.
Windows 7 original.
Radeon HD M6770 drivers ---> 8.950.0.0
IDT drivers ---> 6.10.6329.0
Intel display drivers ----> 6.14.0.3074
Sounds like an issue with the dual GPU's. I would definitely make sure you're using the M6770, and the latest ATI/AMD drivers.
Last HP Bios has a choice between DYNAMIC's option (allows the switch between 2 gpus) and FIXED's option ( allows to use only one of the 2 gpus).
I have FIXED option ON and radeon 6770m selected, or even any single game can't run.
I should switch back to dynamic and chose using the radeon card under XBMC.exe, but i'm sure it doesn't work.
any suggestion?
Definitely leave it set on the 6770 then. Did XBMC generate any
Debug Log before crashing? If so, post it here via pastebin.com
Something should have been generated.
12:19:20 T:3436 NOTICE: -----------------------------------------------------------------------
12:19:20 T:3436 NOTICE: Starting XBMC (11.0-RC2 Git:20120229-f38655f), Platform: Windows 7, 64-bit (WoW) Service Pack 1 build 7601. Built on Feb 29 2012 (compiler 1600)
12:19:20 T:3436 NOTICE: Intel® Core i5-2410M CPU @ 2.30GHz
12:19:20 T:3436 NOTICE: Desktop Resolution: 1366x768 32Bit at 60Hz
12:19:20 T:3436 NOTICE: Running with restricted rights
12:19:20 T:3436 NOTICE: Aero is enabled
12:19:20 T:3436 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
12:19:20 T:3436 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
12:19:20 T:3436 NOTICE: special://masterprofile/ is mapped to: C:\Users\hp\AppData\Roaming\XBMC\userdata
12:19:20 T:3436 NOTICE: special://home/ is mapped to: C:\Users\hp\AppData\Roaming\XBMC\
12:19:20 T:3436 NOTICE: special://temp/ is mapped to: C:\Users\hp\AppData\Roaming\XBMC\cache
12:19:20 T:3436 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
12:19:20 T:3436 NOTICE: Local hostname: hp-HP
12:19:20 T:3436 NOTICE: Log File is located: C:\Users\hp\AppData\Roaming\XBMC\xbmc.log
12:19:20 T:3436 NOTICE: Setup SDL
12:19:20 T:3436 NOTICE: Found screen: Monitor generico Plug and Play on AMD Radeon HD 6700M Series, adapter 2.
12:19:20 T:3436 NOTICE: Primary mode: 1366x768 @ 60.00 - Full Screen
12:19:20 T:3436 NOTICE: Additional mode: 320x200 @ 60.00 - Full Screen
12:19:20 T:3436 NOTICE: Previous line repeats 2 times.
12:19:20 T:3436 NOTICE: Additional mode: 512x384 @ 60.00 - Full Screen
12:19:20 T:3436 NOTICE: Additional mode: 640x400 @ 60.00 - Full Screen
12:19:20 T:3436 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
12:19:20 T:3436 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
12:19:20 T:3436 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
12:19:20 T:3436 NOTICE: Additional mode: 1360x768 @ 60.00 - Full Screen
12:19:20 T:3436 NOTICE: Additional mode: 1366x768 @ 60.00 - Full Screen
12:19:20 T:3436 NOTICE: load settings...
12:19:20 T:3436 NOTICE: special://profile/ is mapped to: special://masterprofile/
12:19:20 T:3436 NOTICE: loading special://masterprofile/guisettings.xml
12:19:20 T:3436 NOTICE: Getting hardware information now...
12:19:20 T:3436 NOTICE: Checking resolution 12
12:19:20 T:3436 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
12:19:20 T:3436 NOTICE: Loaded playercorefactory configuration
12:19:20 T:3436 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
12:19:20 T:3436 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
12:19:20 T:3436 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
12:19:20 T:3436 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
12:19:20 T:3436 NOTICE: Default DVD Player: dvdplayer
12:19:20 T:3436 NOTICE: Default Video Player: dvdplayer
12:19:20 T:3436 NOTICE: Default Audio Player: paplayer
12:19:20 T:3436 NOTICE: Disabled debug logging due to GUI setting. Level 0.
12:19:20 T:3436 NOTICE: Log level changed to 0
12:19:20 T:3436 NOTICE: Loading media sources from special://masterprofile/sources.xml
12:19:23 T:3632 ERROR: CRemoteControl::Connect - failed to connect
