Full Version: Batch of new "Pre-scraped" movies not showing up
I've been adding both TV series just fine, but for some reason a batch of movies I pre-scrape on my desktop PC with Ember won't show up when copied over to my HTPC. When using the Web Manager, I see this under files.
http://i.imgur.com/eFWPH.png
Any idea what I might be doing wrong?
Have you scanned? If so, did you correctly enable "Movies in separate folders named like the movie" ?
Ah that was it! Oddly enough I went to check Folder Settings for my movie folder and somehow the Media Type was set to None instead of Movies. Weird. I have no idea how that happened. But it's all fixed now. Thanks a lot!
