(2013-05-21, 00:18)styxit Wrote: [ -> ]I stored the initd file as /etc/init.d/Htpc chmod 755. That way i can run sudo /etc/init.d/Htpc start and sudo /etc/init.d/Htpc stop
Next i added it to startup with
update-rc.d /etc/init.d/Htpc defaults
Source
Thank you again.... I have configured it and have run into a couple issues.
On Dashboard page, no graphic shows up for any of the recent Movies or TV shows. When going to see the list of movies, they do not sort in alphabetical order, nor do they show the poster image> I get an Error Connection to XBMC notice..
Couchpotato module just keeps the "loading" wheel spinning and nothing shows up.
Sickbeard loads fine including images when looking at specific series.
For XBMC, I use Openelec, and a shared Mysql database. I am using Eden (not Frodo). Sickbeard and Couchpotato are username/password protected.
I am not sure if the above is what is causing my problems.
Thanks again,
H.
(2013-05-20, 21:28)theslimone Wrote: [ -> ]Got this awesome script running on a Windows box with Python 2.7, with only one issue, Couchpotato support seems to be broken at the moment. The "Wanted" tab shows not only my current wanted movies, but everything in the past as well! And when searching for a movie, it does not display anything except this:
https://www.dropbox.com/s/2vkff14zge5ex78/Capture.PNG
Your issue about couchpotato search has been closed:
https://github.com/styxit/HTPC-Manager/issues/8. Go a git-pull,or re-download the code and you should be ok.
The Couchpotato wanted list filter is not yet fixed. Will be done in the near future.
Some other updates include:
Set web dir
If you use a reverse proxy, you want Htpc Manager available at someting like localhost/htpc. this can now be done through the commandline parameter 'webdir' or in the general setting (app restart required).
Reverse proxy support for Sickbeard, sabnzbd and couchpotato
If you use a reverse proxy to make sickbeard (for example) available at localhost/sb you can now enter '/sb' as the base path in the Sickbeard-settings.
Hi, how would one go about installing this wonderful application on Openelec?
Awesome job Styxit!
Nice to see someone finishing what we started.
(2013-05-24, 11:41)SyphOn Wrote: [ -> ]Awesome job Styxit!
Ok I started using this today and I think its great I don't know if you have found the fix for the CouchPotato filter yet but all you have to do is to add the status=active argument to the movie.list api call in couchpotato.py
I got an error when checking for updates: "Your are -1 versions behind". Anyone know what's wrong?
(2013-05-24, 11:45)dakpunne Wrote: [ -> ] (2013-05-24, 11:41)SyphOn Wrote: [ -> ]Awesome job Styxit!
Thanks for your support!
(2013-05-24, 13:20)GlitchZA Wrote: [ -> ]Ok I started using this today and I think its great I don't know if you have found the fix for the CouchPotato filter yet but all you have to do is to add the status=active argument to the movie.list api call in couchpotato.py
I know. It is documented in this issue:
https://github.com/styxit/HTPC-Manager/issues/7 If you want you can fix it yourself by creating a pull request.
(2013-05-24, 17:20)jainoxi Wrote: [ -> ]I got an error when checking for updates: "Your are -1 versions behind". Anyone know what's wrong?
-1 indicates a problem. This is known to me and there is already an issue reported for this.
https://github.com/styxit/HTPC-Manager/issues/2
It requires git command available and does not yet work on windows.
Do not use self update until this is issue is closed. In the meantime, do a git-pull from the commandline, or download the latest version from
http://htpc.io/
(2013-05-30, 02:25)Username2045 Wrote: [ -> ]Issue with no images coming up with the Recently added Movies and TV Shows, Wanted Movies showing every film in Couchpotato (All but 300: Rise of an Empire in my library).
Do images on the xbmc pages work? (By looking at your screenshot i would say yes.) Are you running the HTPC Manager latest version? Do a git-pull, or download the latest version.
- The dashboard recent images have been fixed a few days ago.
https://github.com/styxit/HTPC-Manager/...d804d8
- The Couchpotato movies issue was solved by a pull request
https://github.com/styxit/HTPC-Manager/commit/...001631
Edit: Do you mean couchpotato films on the couchpotato-page or on the dashboard?
I do not really use couchpotato myself, so i can not verify this right now.
I followed the instructions on your website but I have not been able to get this running on localhost:8084. I run the python file and nothing happens on that port.I have tried running through python command and it cant find the file. Running python 64 and have added the PYTHONPATHS stuff in variables. I have couch potato running on 8085 nothing on 8084 that i know of/ can see through browser.
Fixed was running on same port as CP. Shutdown and now accessable, damn im running out of ports in the 80's
The fix for the recent images worked, I thought the Github app auto updated
I meant on the dashboard, actually the couchpotato page too. On the Couchpotato page it should include an "All", "Wanted" and a "Downloaded" tab and should change the current "Wanted" tab to "All" since it currently contains both wanted and archived movies that are in CP.
Some ideas...
Squeeze server needs genre option, sync option.
When squeeze playback a long thin control pannel RSS like bar would be great and look sexy running along the top under modules selection.
Option when adding show through Sickbeard for a different folder location for show. Like different folder for documentary's or cartoons.
And ability to Manual post process folders.
Utorrent support
Links to trailers for wanted movies
(not critical)
I will be able to then use HTPC Manger independently and no longer have to go to other apps directly to control.
Overall a very simple well constructed and elegant application you have created, thankyou.
Like Username2045, i also don't get any images. I know that the updates are manually and i'm currently on the latest update. But whem i look at the XBMC tab, there are no images also. Just the names of the movies, but no posters shown. The same with tvshows, the names are there, but no images.
I'm using Frodo on a raspberrypi with the database located on my Synology(because i have two raspberrypi's with XBMC.
Does anyone know how i can fix this issue?.
Not sure if it auto updated or it just took time to recalculate the films but now the Wanted Movies is now fixed for both the dashboard and the couchpotato page!
What I have noticed is that for some instances in the Recently Added Movies there still won't be an image.
