Full Version: [WIP] HTPC-Manager Beta, Manage XBMC, Sabnzbd, SickBeard with one app
Very nice program.
I have everything I want up and running except Deluge. The Webui is running in my browsers. HTPC Manager can't connect.
I'm on W8.1 x64. Has anybody Deluge running or can someone point me in the right direction?
(2014-04-18, 08:53)hellow Wrote: [ -> ]3 ways: disable the links with js or template, render a other button or use something like this http://tools.cherrypy.org/wiki/Authentic...strictions
That's an interesting link, thanks.
I didn't know CherryPy could support multiple users, much less groups.
I'm gonna look closer when I get a chance.
Great new version. Only one issue, the mobile version struggles with 'other links'. For some reason, I can't click on any of the links I've added on the mobile version - the full Web version works fine though. Any ideas?
Great tool, very nicely done,
i'm running an mysql db for my home XBMC'x,
any chance it could be integrate into HTPC manager, such i don't have to leave an XBMC running ?
Many thanks
(2014-04-24, 20:36)hatton33 Wrote: [ -> ]Great new version. Only one issue, the mobile version struggles with 'other links'. For some reason, I can't click on any of the links I've added on the mobile version - the full Web version works fine though. Any ideas?
I do not have any problems with it, please be more specific so we can help you or fix it if it's a bug. Also, make sure you're running the latest version of HTPC-Manager.
(2014-05-01, 18:32)onlyyou Wrote: [ -> ]Great tool, very nicely done,
Many thanks
Just so you can view your library? No not really. (well, of course it is possible but that is not what HTPC-Manager does.) HTPC-Manager is all about API connections with 3rd party software. It uses the xbmc Api to get your library, and control Xbmc. If xbmc is not running, the api is unreachable. besides, i do not really see the point in showing all your movies/music and series in HTPC-Manager if you can't play them.
If you want an overview of you movie and tvshow library, try couch potato and sickbeard. These also works with HTPC-Manager and can keep track of your movie-library and series.
Many thanks
Depending on what exactly you're after, MovieLib might be what you want. I use MySQL and use MovieLib to let family view my movie/tv show database.
Many thanks
Trakt.tv with the xbmc addon is great.
Many thanks
This is a very good idea, actually. I have code that reads the xbmc dbs (sqlite) and is the start of what I really want to create in a "manager". Reading a MySql db is just the next logical step.
(2014-05-01, 18:44)styxit Wrote: [ -> ]
Sure - definitely the latest version. It occurs when I add more than one item to 'other links' which then creates the 'drop down' style menu. This works fine on the full site version, but using the mobile one, on either iOS or Android, it shows the links under the 'other links' sub menu, but no matter where you tap, its not possible to select them, all that happens is that you open / close the other links menu. Hope that makes sense.
(2014-05-03, 23:44)hatton33 Wrote: [ -> ]
I understand what you mean, same happens on my phone. Its not really a issue for me since the only links i have there is on lan access only anway. But it would be nice if it worked there aswell. I made a issue on github.
Htpc-manager now supports plex. Thanks tester22!
(2014-05-25, 18:41)hellow Wrote: [ -> ]Htpc-manager now supports plex. Thanks tester22!
What ever was just done, it literally halted my system to a crawl!
https://www.dropbox.com/s/es2lenp6in74rbl/htpc1.PNG
https://www.dropbox.com/s/bw6vshmzuz8niuy/htpc2.PNG
and altered the page.
https://www.dropbox.com/s/wosc2j7w6j9104n/htpc3.PNG
(2014-05-25, 20:07)ylafont Wrote: [ -> ]
Tried a reboot? Its using less then 1% here. usually 0%
Regarding the menu: your menu names are to long as they dont get truncated/grouped. Untill that changes you should have shorter names.
(2014-05-25, 22:53)hellow Wrote: [ -> ]Tried a reboot? Its using less then 1% here. usually 0%
I could have sworn i reboot twice before posting! Seems to be ok now
On the menus, What is the sense of placing those items there when there already in the gear menu next to the search ? shouldn't this be an option?.
What is the sense of the the second search on the top?
all this screen real estate and now i have bigger menus.. seams we are going the the wrong direction.
Am i missing something?
(2014-05-26, 02:19)ylafont Wrote: [ -> ]I could have sworn i reboot twice before posting! Seems to be ok now
I knew i had rebooted. Back at 100% memory utilization.
