Full Version: [WIP] HTPC-Manager Beta, Manage XBMC, Sabnzbd, SickBeard with one app
(2014-06-08, 20:29)lallhands Wrote: [ -> ]Anyone else experiencing no movies listed in wanted or history in couchpotato interface? Movies are successfully added to couchpoatato through the interface, so API key is good, but it looks like there is a failure of the query when looking for wanted movies or history - they are just blank. This has happened on several machines just recently (I believe in the last week).
Thanks for any help in advance!
Cp module is broken due to changes in the couchpotato api. It need to be updated.
After a recent Couchpotato update, the api was no longer behaving the same way it did before. We had to do some changes in HTPC-Manager to get it working again. Try updating HTPC-Manager and Couchpotato to the latest version. Not everything works like before, but we're on it.
I should have a fix shortly. Just cleaning up the code
Its posted now i think everything is working as it should.. But if any want to test just to make sure. You can find it here: https://github.com/Hellowlol/HTPC-Manage.../cp-newapi
Is NzbDrone support coming? Thanks Smile
I dont think any is working on it
The problem with NzbDrone is the weak api.
I'm starting to look at the Sick-Rage fork. It has the same great api, and is trying to address failed downloads...which is all I see NzbDrone brings to the table.
I didnt find the api docs, from what understand i have to download the app to check it. I didnt look that hard, but i think the docs should be on the front page. Now that just pisses me off.
I have posted this memory issue with the last update, and the problem still persist. I thought the problem was resolved with a reboot but It comes up intermittently.
https://www.dropbox.com/s/2lngn2yb5mw28dm/htpc.png
Just wanted to let you know.
(2014-06-17, 20:10)ylafont Wrote: [ -> ]I have posted this memory issue with the last update, and the problem still persist. I thought the problem was resolved with a reboot but It comes up intermittently.
Thankyou! I try to keep HTPC-Manager as light weight as possible, but with support for al different kinds of software that is not always easy.
I can't really reproduce your issue so if you can give me any more details that would be helpful. Like what are the system specs and platform. im really interested in this issue because i do not want HTPC-Manager to consume all system resources.
log might be usefull aswell. Its working fine here.
(2014-06-17, 21:42)styxit Wrote: [ -> ]
I will try to reproduce it and send the log. Which log file do you need? The log interface is empty.
Debug log would be best
(2014-06-17, 01:11)MadClicker Wrote: [ -> ]The problem with NzbDrone is the weak api.
Sickrage works with both pytunes and htpc manager Big Grin
