Full Version: [WIP] HTPC-Manager Beta, Manage XBMC, Sabnzbd, SickBeard with one app
014-08-22 02:00:30 :: root :: INFO :: Welcome to HTPC-Manager!
2014-08-22 02:00:30 :: root :: INFO :: Loglevel set to info
2014-08-22 02:00:30 :: htpc.updater :: INFO :: Using GitUpdater engine
2014-08-22 02:00:30 :: modules.xbmc :: INFO :: Selecting XBMC server: 6
2014-08-22 02:00:30 :: modules.stats :: ERROR :: Could't import psutil. See https://raw.githubusercontent.com/giampa...NSTALL.rst
2014-08-22 02:00:30 :: htpc.server :: INFO :: Starting up webserver
2014-08-22 02:00:30 :: cherrypy.error :: INFO :: [22/Aug/2014:02:00:30] ENGINE Listening for SIGHUP.
2014-08-22 02:00:30 :: cherrypy.error :: INFO :: [22/Aug/2014:02:00:30] ENGINE Listening for SIGTERM.
2014-08-22 02:00:30 :: cherrypy.error :: INFO :: [22/Aug/2014:02:00:30] ENGINE Listening for SIGUSR1.
2014-08-22 02:00:30 :: cherrypy.error :: INFO :: [22/Aug/2014:02:00:30] ENGINE Bus STARTING
2014-08-22 02:00:30 :: cherrypy.error :: INFO :: [22/Aug/2014:02:00:30] ENGINE Forking once.
2014-08-22 02:00:30 :: cherrypy.error :: INFO :: [22/Aug/2014:02:00:30] ENGINE Forking twice.
2014-08-22 02:00:30 :: cherrypy.error :: INFO :: [22/Aug/2014:02:00:30] ENGINE Daemonized to PID: 27076
2014-08-22 02:00:30 :: cherrypy.error :: INFO :: [22/Aug/2014:02:00:30] ENGINE Started monitor thread '_TimeoutMonitor'.
2014-08-22 02:00:30 :: cherrypy.error :: INFO :: [22/Aug/2014:02:00:30] ENGINE PID 27076 written to '/usr/local/htpcmanager/var/htpcmanager.pid'.
2014-08-22 02:00:30 :: cherrypy.error :: INFO :: [22/Aug/2014:02:00:30] ENGINE Serving on 192.168.0.100:8087
2014-08-22 02:00:30 :: cherrypy.error :: INFO :: [22/Aug/2014:02:00:30] ENGINE Bus STARTED
2014-08-22 02:00:31 :: cherrypy.error :: INFO :: [22/Aug/2014:02:00:31] ENGINE Started monitor thread 'Session cleanup'.
2014-08-22 02:00:46 :: modules.xbmc :: INFO :: Suspending XBMC
2014-08-22 02:03:05 :: modules.xbmc :: ERROR :: [Errno 113] No route to host
File "/volume1/@appstore/htpcmanager/share/HTPC-Manager/modules/xbmc.py", line 631, in GetRecentMovies
return xbmc.VideoLibrary.GetRecentlyAddedMovies(properties=properties, limits=limits)
File "/usr/local/htpcmanager/share/HTPC-Manager/libs/jsonrpclib/jsonrpc.py", line 276, in __call__
return self.__send(self.__name, kwargs)
File "/usr/local/htpcmanager/share/HTPC-Manager/libs/jsonrpclib/jsonrpc.py", line 224, in _request
response = self._run_request(request)
File "/usr/local/htpcmanager/share/HTPC-Manager/libs/jsonrpclib/jsonrpc.py", line 242, in _run_request
verbose=self.__verbose
File "/usr/local/python/lib/python2.7/xmlrpclib.py", line 1264, in request
return self.single_request(host, handler, request_body, verbose)
File "/usr/local/python/lib/python2.7/xmlrpclib.py", line 1292, in single_request
self.send_content(h, request_body)
File "/usr/local/htpcmanager/share/HTPC-Manager/libs/jsonrpclib/jsonrpc.py", line 122, in send_content
connection.endheaders()
File "/usr/local/python/lib/python2.7/httplib.py", line 969, in endheaders
self._send_output(message_body)
File "/usr/local/python/lib/python2.7/httplib.py", line 829, in _send_output
self.send(msg)
File "/usr/local/python/lib/python2.7/httplib.py", line 791, in send
self.connect()
File "/usr/local/python/lib/python2.7/httplib.py", line 772, in connect
self.timeout, self.source_address)
File "/usr/local/python/lib/python2.7/socket.py", line 571, in create_connection
raise err
error: [Errno 113] No route to host
BTW thanks for looking into this.
Check you settings again.
well it is weird because the app sends a suspend so surely the setting must be correct.
It tries to suspend, the message is not recived. Does the other things in the xbmc module work? Can you see the show, see what's playing and so on?
I can see all my movies and TV shows , I can see the latest movies and TV shows I can move around the menus, on XBMC from HTPC manager I can send suspend, shutdown and restart commands.
However when I send wake command it fails. Is this something to do with my synology hosting HTPC manager?
Dunno mate all I can say that works here. I don't bother turning stuff on tho. Nucs use like 10 w
Anyone else on a synology got this working?
This is a bad ass Front end. Love it. Can't wait to see Headphones included Smile
out of interest the wake from suspend works on XBMC Video Server and my xbmc box.
just noticed the wake on lan does work but there is a delay of around 60 seconds before XBMCbuntu starts to wake up where as XBMC Video Server send the wake up command and it is almost immediately back online.
Feature request ---
-- ability to select and play a music playlist.
-- Create and modify a music playlist from the web interface would be ideal ! 8-)..
(2014-09-03, 05:10)ylafont Wrote: [ -> ]Feature request ---
In xbmc, plex or both?
(2014-09-03, 09:47)hellow Wrote: [ -> ]
I would say both.! Although I am XBMC user, i do use Plex for remote access.
I want to add a feature request as well. Is it possible to show the release date of NZBs for CP module and NZB search. There are is lot of information already visible but this one is one of the most important IMO.
thanks for considering!
Just a tip: feature requests should be made on github. It's more likely that someone will add it. I do I like the requests and am bored.
I think there are a playlist option today in the xbmc module. I don't use it, but there are some code related to it.
